Re: Spindle transfer
There is also an interference parameter so as to keep the spindles from colliding. The parameter is under Spindle 1-2 if I remember correctly. It works rather strange in that the number cannot go negative and may already be at zero but you need spindles to move closer together. The trick is to SET the parameter to say 10000 (10mm) and then ADD -10000. This will allow the spindles to move closer by 10 mm. Of course you cannot exceed your stroke limits so take that into consideration.
Best regards,
Experience is what you get just after you needed it.
