585,712 active members*
4,006 visitors online*
Results 1 to 3 of 3
    Nov 2018
    Spindle transfer
    Hi, I'm new to okuma lb3000 ex and I'm trying to program my transfer from spindle A to spindle B. I keep getting w axis over travel axis alarm. But it's not even close to being able to grab the part. Also I have used different thickness of soft jaws and it happens at the same spot every time. Please help.
    Jun 2015
    4154
    Re: Spindle transfer
    hi, in here, at post 8 is a *pdf sample for part transfer : https://www.cnczone.com/forums/okuma...er-cutoff.html
    you may need to shift the coordinates, so to get closer to main spindle : just go easy, shift with 1mm, then another 1mm, etc, observe, be carefull / kindly
    Apr 2009
    1262
    There is also an interference parameter so as to keep the spindles from colliding. The parameter is under Spindle 1-2 if I remember correctly. It works rather strange in that the number cannot go negative and may already be at zero but you need spindles to move closer together. The trick is to SET the parameter to say 10000 (10mm) and then ADD -10000. This will allow the spindles to move closer by 10 mm. Of course you cannot exceed your stroke limits so take that into consideration.
    Best regards,
  1. Conquest T42: How do you program a sub-spindle transfer?
    By torinwalker in forum Hardinge Lathes
    Last Post: 07-03-2022, 07:46 PM
  2. Nakamura sub spindle wont transfer
    By nottoshabbie in forum Uncategorised MetalWorking Machines
    Last Post: 07-13-2016, 01:44 AM
  3. Type3 4.3 transfer, Artcam Express 2012 transfer
    By frankleng in forum For Sale Only
    Last Post: 05-15-2014, 03:28 AM
  4. Transfer HSP to V24 from V23
    By seal1966 in forum BobCad-Cam
    Last Post: 01-17-2011, 08:28 AM
  5. how to transfer?
    By hop in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-15-2006, 05:35 AM
