585,712 active members*
3,883 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Tormach PathPilot™ > Anybody is using the inputs on USB I/O board ( the one with the output relays)
    May 2008
    667
    I have a digital part counter connected to one of the output relay of the USB I/O board.
    The counter has a relay on the output also and I would like the lathe to stop when input 1 is high or low.
    I also use the counter inside the program.
    Could somebody give me some help on using inputs and how do I program it in pathpilot.
    Thanks in advance.
    Jeff
    This is a picture of the counter I'm using
    Apr 2013
    1788
    Re: Anybody is using the inputs on USB I/O board ( the one with the output relays)
    There are examples in the USBIO manual (https://www.tormach.com/support/wpdm...all-0717a-web/). See page 5 for an example of using M66. You can check an input, wait until an input is high or low or wait until an input changes.
    Dec 2008
    740
    Quote Originally Posted by jeffrey001 View Post
    Did the response from kstrauss answer your question?
    Step
  1. Replies: 0
    Last Post: 08-07-2016, 11:01 PM
  2. C23 board relays
    By Sweeney in forum CNC4PC
    Last Post: 03-24-2016, 01:37 AM
  3. I need 6 inputs, but my breakout board has only 5, how?
    By lucky021 in forum Canadian Club House
    Last Post: 06-13-2010, 09:28 PM
  4. Breakout board, Relays on board?
    By Cooper in forum Open Source Controller Boards
    Last Post: 06-10-2007, 01:55 AM
  5. Encoder output into 2 different inputs?
    By murphy625 in forum Servo Motors / Drives
    Last Post: 03-23-2005, 04:36 PM
