585,948 active members*
3,706 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Not sure what motion controller to use
Results 1 to 10 of 10
    Feb 2018
    8
    Hello, I will be building an epoxy granite VMC, my plan is to use BT30 ATC spindle powered by 2.2kW CTB servo. In the future, I will also make umbrella style fully automatic tool change. I want to know whitch motion controller would be suitable for this application? How do I tell the servo drive the exact RPM in needs to spin, example: rigid tapping. Servo drive supports RS232, RS485 for MODBUS protocol, and also EtherCAT communication. I will attach photos from datasheet for more info. Do I have to use a motion controller that supports one of those protocols? My knowledge in this area is not very good so please enlighten me if I said something that doesnt make sense.
    Attached Thumbnails Attached Thumbnails ctbservo.PNG   ctbservo2.PNG   ctbservo3.PNG
    Feb 2018
    8
    Re: Not sure what motion controller to use
    Would MODBUS work with RS485, ethernet smoothstepper and mach3 brain?
    I don't believe you can control motion with Modbus in Mach3.
    It looks like you can use Step/Dir with the A and B terminals on T4.
    Or, you can use analog ±10V.
    Feb 2018
    8
    I will look more at Step/Dir on T4, thanks.
    Analog 10V would work, but it doesnt give me precise enough rpm for rigid tapping right?
    With a servo with encoder, it should be just as precise as step/dir.
    Note that you'll need an analog capable controller, which is typically much more expensive.
    I would not recommend using Mach3 on a new machine, as it's development stopped years ago.
    You might want to look at the Centroid Acorn, LinuxCNC, UCCNC, or EdingCNC.
    Feb 2018
    8
    Thought about using Mach3 because I already use it on my router. But i dont mind having to learn new software, as long as there is some support online.
    Will look more into Acorn, it has direct spindle encoder feedback and rigid tapping, which is what I want. Does this board work only with their software?
    About LinuxCNC, what board to use? mesa?
    For UCCNC, i need ESS board, but it doesnt have a proper interface to fully control servo spindle drive.
    Haven't heard of EdingCNC tho.
    Thanks for help!
    UCCNC does NOT work with ESS, only with CNC Drive control boards.
    Jul 2003
    1754
    Linuxcnc works with ethercat..
    https://forum.linuxcnc.org/24-hal-co...driver?start=0
    Also. Mesa is certainly a good company.
    Jul 2003
    1754
    And can do rigid tapping
    Jun 2015
    943
    No, for UCCNC you need one of their motion controller, not an ESS.
    UCCNC can do rigid tapping with spindle encoder feedback.
    https://www.youtube.com/watch?v=QqNfKvWuOBI
    It can also control servo spindle, it supports step/dir spindle mode.
  1. Replies: 4
    Last Post: 04-18-2024, 11:10 AM
  2. Looking for a PWM Motion Controller
    By Jrjones in forum Controller & Computer Solutions
    Last Post: 08-25-2015, 05:24 PM
  3. CNC USB motion controller
    By Kroko in forum News Announcements
    Last Post: 01-03-2014, 01:58 PM
  4. Motion Controller
    By Joshua Sendawul in forum Multicam Machines
    Last Post: 07-31-2013, 03:22 AM
