585,962 active members*
4,068 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > V30 outputting arc calculation error
Results 1 to 7 of 7
    Aug 2010
    188
    my V30 with okuma osp200 post processor is outputting an arc calculation error, ive used this post hundreds of times and never had an issue, anyone have any insight on this? where to start looking? its a large program and i couldnt possibly track down the error and make the corrections manually. thanks.
    Apr 2009
    3376
    Re: V30 outputting arc calculation error
    Does it error when running in Preditor Editor Backplot ?
    If so that would be it where it stops
    Or does it error only at the machine ?If so that part of the program where it goes screwy should point to it
    Do you not have any line numbers in program ?
    What kind of part you running.An engraving ?
    Engraving of .dxf files can sometimes give problems
    Track down with Preditor when and where it happens
    Sometimes it is just a slight drawing error
    Dec 2008
    4548
    Couple things.
    Did you set arc fit at the feature level?
    There are a couple places in the post processor to set arc handling that can help with large calc files.
    As jr mentioned, geometry can be the culprit.
    Where in the chain is the error? Ie; upon caculation, simulation, posting, at the machine control, etc.......
    Aug 2010
    188
    i tried to chase down the problem manually but gave up. i tightened up the arc fit and it is now running, the new problem im having is the machine will stop momentarily everytime it switches between a G01, G02, G03 command and being that the program is now broken down into tiny line and arc segments, the machining process looks like sh*t.....
    i suspect this is something in my controller that i need to address? a look ahead parameter or something of the sort?
    Apr 2009
    3376
    Is it a 3d tool path,engraving ???
    can you share a file,,or pm it
    Dec 2008
    3109
    Quote Originally Posted by jay_dizzle View Post
    I assume the machine is a mill...
    ... small linear moves are what is creating the stutter ( executing the moves faster than what the program can be read... a standard issue ) (Adjusting or turning OFF tolerance control in the machine may improve smoothness ... if you have it )
    look to see if the CAM system can "fit arcs" to the calculated paths to minimise the point-to-point programming..... Maybe something related to "tolerance" or "fit arc tolerance"
    .... some CAM systems output small line segments on splines, you may have to replace splines with arcs before creating the toolpaths.
    Aug 2010
    188
    Quote Originally Posted by Superman View Post
    it seems as though i need to change the arc fit tolerance in the CAM system to match the maximum allowable deviance that is set in the machine parameters, this would give me the smoothest machining operation while still staying within the allowable amount of arc calc error.
    Quote Originally Posted by jrmach View Post
    it was a 3D tool path, unfortunately, i deleted the file (i had a bit of a temper tantrum) and started fresh, i messed with the arc fit tolerance and matched them to the machine parameters, the process got a lot smoother and the alarms are no longer an issue.
  1. Outputting for someone else's machine
    By jegero in forum Alphacam
    Last Post: 02-08-2017, 04:44 PM
  2. Outputting File
    By Todd Zuercher in forum Fanuc
    Last Post: 04-12-2010, 02:00 PM
  3. NX6 Probing and outputting
    By i0wa in forum UG NX
    Last Post: 12-03-2009, 07:19 PM
  4. Outputting programs from Fanuc MV-40B
    By jakeb in forum Fanuc
    Last Post: 02-23-2009, 05:17 PM
  5. Outputting to USB or MDI
    By pants in forum Haas Mills
    Last Post: 06-10-2008, 12:58 AM
