585,996 active members*
3,850 visitors online*
Results 1 to 9 of 9
    Apr 2019
    7
    CW8060 connection
    I am new here.
    Can anyone help me to connect CW8060 driver to the breakout board?
    CP+
    CP-
    CW+
    CW-
    EN+
    EN-
    Thanks!
    Mar 2007
    2083
    Re: CW8060 connection
    once you deside if your going to use a common +5V connection to CP+ , CW+ & EN+ or common -5V connection to CP- , CW- & EN- to the CW8060 stepper drivers
    assuming your using Mach 3 in pins and ports you will need to assign the function of the BOB output pins P4 to P9 and pins P16 & P17
    by default if you don't connect the stepper driver enable terminals (EN + EN-) the driver will be enabled
    so the minimum connections to the driver is the common +5V or 0V , clock pulse CP and Direction CW
    for a 4 axis machine you could make
    P9 the X axis CP P8 X axis CW
    P7 the Y axis CP P6 Y axis CW
    P5 the Z axis CP P4 Z axis CW
    P17 the A axis CP P16 A axis CW
Name:	BOB to driver connections.jpg
    John
    Apr 2019
    7
    Many thanks John!
    Apr 2019
    7
    After wiring like this, all is ok and not.
    Some times motors run some times not, when push Jog +/-.
    Or run X + and Z + or Z- not..etc
    I have to play many times with all X+-/Y+-/Z+- Joging to get some movements from motors.
    I've measured 5V pin and get me 2.4V.
    Could be this a problem?
    Mar 2007
    2083
    view2
    when did you measure 2.4V on a pin ?
    assuming your using a multimeter
    you will see the direction pin toggle between 0V & 5V as you change direction
    while jogging , the step pin will switch between 0V & 5V so fast the meter will
    display the average voltage
    if the pin is at 0V 50% of the time the voltage displayed will be about 2.5V
    John
    Apr 2019
    7
    Thanks guys.
    1.In the John's "BOB to driver connections.jpg" above, CP+, CW+ go to + 5V but in the "automationtehnologies" pdf wiring, CP+ and CW+ go to GND.
    Wich one to consider ok?
    2. I still have the problems with the stepper motors:
    My actual connection is CP+ , CW +, EN+ go to +5V, CP- to pin 4, CW to pin 5, EN- to pin 16 for X axis for example
    In Mach3, Dir and Step are set as LowActive and Enable1 is also Active Low
    When measure with multimeter between GND and pin 4 (as example) it give me 2,4 V even if I am joging in + or -. So when jog the 2.4V is the same value
    Any ideas?
    I measured
    Mar 2007
    2083
    for the LED inside of an opto-isolator use in the stepper drivers to light
    the anode has to be made positive with respect to the cathode
    the volt drop across the LED depends on the colour
    for a red LED the volt drop will be about 1.8V
    with a 5VDC supply to the driver step , direction & enaple inputs
    the 270 ohm resistor will limit the LED current to about 12mA
Name:	opto-isolator 5V input.jpg
    John
    Apr 2019
    7
    I've solved the problems!
    I didn't know that the breakoutboard it should be connected also to USB computer in order to get +5V )
    Thanks guys
  1. CONFIGURACION 8 PINES EN MICROSTEP DRIVER CW8060
    By betocxCNC in forum Benchtop Machines
    Last Post: 08-21-2017, 05:26 AM
  2. Arcing connection on Laser CO2 tube connection
    By pcaulfie in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 11-06-2015, 07:00 PM
  3. C-tek km-150 232 connection
    By JJLKewL69 in forum USB, RS232, PARALLEL etc
    Last Post: 07-09-2015, 03:13 PM
  4. DM870 vs CW8060
    By LEG4CY in forum Stepper Motors / Drives
    Last Post: 03-13-2013, 09:17 AM
  5. DB9 Connection
    By denz in forum Gecko Drives
    Last Post: 09-12-2009, 11:49 AM
