585,743 active members*
4,744 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Arduino > arduino grount to chassis ground??
Results 1 to 17 of 17
    Mar 2011
    357
    When setting up a CNC using Arduino UNO do I need to connect one of the grounds on the Arduino board to the chassis ground? The same one that comes from the wall?
    1943
    Re: arduino grount to chassis ground??
    yes
    Mar 2015
    409
    There is no need to connect the arduino GND pin to the Earth ground or any chassis ground. If you do, ground loops can destroy the Arduino or generate hard to find errors. This is also the reason you should not use the chassis ground as signal transmitter. The chassis ground should be connected to the earth pin on the wall outlet. Because it is probably made of aluminum you should use a toothed washer between the chassis and the screw to make a good connection (Aluminum is always covered with an thin oxidized layer).
    Mar 2011
    357
    ok now who is right??
    May 2015
    1422
    Both?
    Use a multimeter to ensure that arduino's power supply's input ground is connected to its negative output. If it doesn't, ie it's floating, I'd consider replacing it because you have no idea what potential it's floating around at.
    Bond the supply input ground to a star point on the chassis which leads off to the earth pin, with the star washer etc.
    Don't use the chassis as an earth wire for the arduino inputs or outputs, though - run a separate lead to wherever you're going. Eg running a single wire to an endstop and using the chassis as a ground might work when you try it but guaranteed it's going to cause freakiness when you need it to be stable.
    Mar 2011
    357
    My arduino is getting it's power from the USB cable. No separate power supply.
    Is that a problem?
    May 2015
    1422
    The USB breakout I had before I replaced it with an ethernet one was like that - completely floating, no grounding, nothing.
    I used to get a 2mm spark when I plugged it into the computer, across the shield line. You can't tell me that's good. I also got a bunch of interference issues - until I grounded the frame of the machine to the same earth that the computer was grounded to (on the power board). If the arduino is talking to stepper drivers or a VSD then it's going to ground through them anyway, so I wouldn't get too worried about it.
    1943
    There should be a common ground point on the chassis and all components should ground to this point including the negative terminal of any power supplies, the Arduino ground, the 120VAC ground wire, and other individually-powered components. This is referred to as "star" grounding and If they are all going to the same ground point then there should not be a ground loop issue.
    Mar 2011
    357
    Quote Originally Posted by hfjbuis View Post
    why the toothed washer? Aluminum and aluminum oxide are both conductors.
    24220
    Quote Originally Posted by tkms002 View Post
    Is that a problem?
    The power common terminal of a USB socket in a Tower or Desk Top PC is connected to earth ground via the Mobo power supply common and the board ground plane, which is connected to the chassis and hence sourced from the earth pin on your power socket.
    There is no problem in taking any processor to ground as long as it is done correctly.
    The Galil Motion boards I use also do this automatically via the PC P.S. earth ground.
    It occurs exactly the same with the printer port common.
    Al.
    Albert E.
    Mar 2015
    409
    Whenever you make a electrical (screw) connection to an protected conductive (painted steel,stainless steel, aluminum, titanium, etc) you need a toothed washer. When tightened, the tooth "make sure" there is a good electrical connection even is the surface is painted or oxidized. Whenever you loosen the srew connection, you have to change the toothed washer.
    Most (dry) oxides are not conductive,
    Here a WIKI quote:
    Al2O3 is an electrical insulator but has a relatively high thermal conductivity (30 Wm?1K?1) for a ceramic material. Aluminium oxide is insoluble in water. ... Aluminium oxide is responsible for the resistance of metallic aluminium to weathering.
    Mar 2011
    357
    Here a WIKI quote:
    Hmm.
    If I put a continuity tester on the surface it makes a connection.
    Mar 2011
    357
    Al.
    I am using a laptop that is not always plugged in.
    Mar 2015
    409
    You mean, the probe is able to break through this oxidized layer. Probes should have a very sharp point. Enen if you use a (soft) copper wire, you will probably measure conductivity, the question is if this conductivity will last during the lifetime of the machine.
    In Europe this toothed washer is a safety requirement.
    May 2015
    1422
    Which changes things because most laptops don't even have a third pin for ground (at least in Oz). So you need a way of locally grounding your arduino and, indeed, the laptop via the USB connection so everyone's talking the same reference zero voltage. Star point ground, even consider soldering a nice fat wire to the board next to the USB connector's shield to that star point as a low impedance path for normalising voltages from the laptop.
    Most places it is. Don't forget that brushing a probe on continuity sense has a very low current and thus minimal voltage drop across the connection. Crank up the current and you may find that the connection to an oxidised ali surface creates such a high voltage drop it becomes next to useless.
    Mar 2011
    357
    thanks I will add them
    Mar 2011
    357
    Quote Originally Posted by dharmic View Post
    my laptop does have a third wire on the charging cord. When I created my electronics box I added a grounded 120v power outlet that I plug the laptop into.
    So, I will run a wire from the Arduino GRD to my common ground(a bus bar). I will add star washers in between the ground bus and the chassis.
  1. Keep arcing chassis on Geckos??
    By Zeppelin1007 in forum Gecko Drives
    Last Post: 02-13-2018, 09:57 PM
  2. Drawing a chassis
    By motas in forum Hobby Discussion
    Last Post: 11-24-2010, 10:40 AM
  3. Frame ground vs. Electrical ground.
    By polaraligned in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-24-2008, 11:21 PM
  4. RFQ Amp Chassis
    By osoloco69 in forum Employment Opportunity
    Last Post: 11-09-2007, 04:56 PM
  5. Motor supply ground vs Logic ground?
    By Gashmore in forum CNC Machine Related Electronics
    Last Post: 06-07-2005, 11:21 PM
