585,987 active members*
4,504 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > pls, how to disinfect the coolant tank?
    Jun 2015
    4154
    Hello, I took out the coolant tank and washed it, now is dry and want to put it back. I was thinking to disinfect it before but I don't know with what: spirit, kitchen disinfectant, or to spray some vodka on it and on me ????
    Nov 2005
    196
    Re: pls, how to disinfect the coolant tank?
    Save the vodka for yourself. Just letting it sit dry overnight should be good enough. Chlorine in the water will kill anything that's left. If you really want to do something extra you can use bleach or rubbing alcohol.
    Jun 2015
    4154
    hy ted, i just finished : i washed it at a car wash, then i cleaned the rests with napkins + clean coolant; after it dried, i used napkins + desinfectant
    i don't like the swamp that appears inside these tanks
    i generally clean them 2 times / year :
    ... spring - summer : 1 nice clean, including tank wash, chuck apart & cleaning, cleaning behind the covers, coolant pump clean, etc
    ... near winter : only a quick coolant tank clean, removing as much of the swamp as possible, without emptying the tank
    kindly
  1. coolant tank for ZL-25B/500
    By Wheels600 in forum Mori Seiki lathes
    Last Post: 12-19-2012, 03:10 PM
  2. Coolant Tank
    By bookerandrew in forum Bridgeport / Hardinge Mills
    Last Post: 03-13-2010, 06:52 AM
  3. coolant tank lid leaking
    By R.DesJardin in forum Tormach Personal CNC Mill
    Last Post: 01-29-2009, 03:18 PM
  4. vf-3 coolant tank
    By GENMACH in forum Haas Mills
    Last Post: 07-17-2007, 09:04 PM
  5. Coolant Tank
    By GITRDUN in forum Haas Mills
    Last Post: 09-15-2006, 06:00 PM
