585,737 active members*
4,543 visitors online*
Results 1 to 12 of 12
    Mar 2011
    357
    skate bearing dust problems??
    For those of you that have or had a skate bearing machine do you or did you have issues with dust collecting on the rails and bearings and causing issues like stalling and rumbly movement?
    If so, have you fixed it and how?
    35538
    Re: skate bearing dust problems??
    The CNCRP skate bearing carriages are very intolerant of dust, as it doesn't take much to cause binding.
    My skate bearings roll on round pipe, which is much more forgiving, but not quite as rigid.
    You may be able to fabricate some felt "wipers" to clean the rails ahead of the bearings? Adding oil to the felt also lubricates as it cleans.
    You could also add some type of brush to clean them.
    15362
    Quote Originally Posted by tkms002 View Post
    Are the Bearing number end with 2RS or with a Z type Shield
    Mactec54
    Mar 2011
    357
    They are yellow jacket ABEC 9 skateboard bearings.
    15362
    The yellow seal could mean that they are 2RS which is sealed post a photo I will tell you for sure if they are sealed or not
    Mactec54
    35538
    Hes not talking about dust IN the bearings, but the bearings rolling over dust and chips.
    15362
    It does not take long for the bearing like this to jam up with dust if they are not 2RS type shielded Bearings, he needs to know all the problems with this type of rail system you covered only one part I cover the other part
    Mactec54
    Feb 2005
    829
    the bearings are double shielded. I have been running them for 4 years without issue of the bearing themselves. Rails and outside of the bearing race can buildup packed dust, so keeping them clean will make the machine work better.
    Nov 2015
    31
    crp sells, or did sell a kit that adds brushes to either side of the bearing carriers. I use them on my router, still have to clean the rails with a brass brush occasionally but no where near like before the brushes.
    15362
    Quote Originally Posted by nlancaster View Post
    Yes well there is a difference between Bearing double shield types ZZ shields are ( 2 ) metal shields which are very common which don't seal the bearings completely, then there are 2RS which are ( 2 ) rubber seals, so the wording Double Shielded is not correct as there are more than (1 ) type of shield each has it's own name and is part of the Bearing standard ISO part number
    Mactec54
    Mar 2011
    357
    here is a pic of each side of the bearings.
Name:	bearing pic 2.jpg
Name:	bearing pic 1.jpg
    15362
    The Bearings you have are 2RS, this type of Bearing was never designed to be used like this, as the outer Bearing race is quite thin and can crack quite easy with any over loading, as it is not contained like it should be, there are special Bearings called cam followers that can be used for this kind of rolling motion, with no worry of over loading
    Mactec54
  1. New skate bearing idea
    By grumpygeek in forum DIY CNC Router Table Machines
    Last Post: 06-12-2013, 02:49 PM
  2. Which Skate Bearing Design Is Better?
    By Dman65 in forum Linear and Rotary Motion
    Last Post: 08-05-2009, 01:19 PM
  3. Lifespan of a Skate Bearing.
    By Miata2k in forum DIY CNC Router Table Machines
    Last Post: 09-22-2006, 06:53 PM
  4. skate bearing design
    By paul langwade in forum DIY CNC Router Table Machines
    Last Post: 07-30-2006, 01:56 AM
  5. Skate Bearing Design
    By coolman in forum DIY CNC Router Table Machines
    Last Post: 05-20-2005, 07:25 PM
