584,857 active members*
4,113 visitors online*
IndustryArena Forum > MetalWorking Machines > Hyundai Kia > Hyundai-Kia VX500 Spindle V-Belt
Results 1 to 1 of 1
    May 2019
    Top 5 Best Small Pocket Knife For Everyday Use
    There are times that having a knife ready is not only convenient but indispensable. For example, during camping, we would need to open a can or split firewood for starting a fire. In car accidents, a knife can be used to cut the seat belt for quick and timely evacuation from inside a dangerous vehicle.
    Or when you are at a company office opening a package, or cutting out pieces of paper, a knife will make your day’s work much easier. The problem is a normal knife, like a butcher’s knife or fruit knife, is kind of dangerous and alarming to just carry around.
    For these occasions, the Best Rated Pocket Knife - Top Pocket knife in the World is just perfect. It is a small, and foldable, that can be easily and safely kept inside your pockets or bags.
    With the advancement in material manufacturing, better and better knives are being available to consumers, but it also means buyers can be easily hit with low-quality materials, or worse, counterfeit products that cost as much as authentic ones.
    For that reason, to save you valuable time and a lot of head scratching, we have put together this review of the 5 best small user pocket knife for everyday use.
    1) Spyderco Dragonfly 2 Folding Knife
    The Dragonfly 2 is one of the best small lightweight pocket knife models, and upgrades many of the great classic features from its predecessor. The blade length is 2.3 inches and made of 100 percent rust-proof H1 stainless-steel, which is ideal and indispensable for harsh conditions or if you simply want a low maintenance blade.
    Pros
    • Handle is made from Fiberglass Reinforced Nylon (FRN), which is a polymer mixed with fiber glass, then injected into a mold, resulting in a lightweight yet exceptionally strong and durable material.
    • The handle is shaped to be comfortable and provides protection for your fingers.
    • H1 stainles-steel has optimal strength and highest level of corrosion resistance of any knife metal. It will hold its edge and is easy to sharpen or grind.
    Cons
    • Blade is a little bit small.
    2. Small White Texas Toothpick Pocket Knife
    The Small Texas Toothpick has a small design, so small in fact you barely notice it in your pocket. But it is a knife you will love with its quality and beautiful craftsmanship. This knife is great idea for everyday use, or camping and outdoor activities. It is simply one of the Best Quality Pocket Knife - Top Rated Folding Knife for using everyday.
    Pros
    • The slim blade is about three inches long, made of Tru-Sharp stainless steel, which is a special high-carbon steel that is used in surgical knives and helps the blades retain its edge longer than conventional stainless steel.
    • Can choose from two variations for the handle: synthetic or bone.
    • Small and compact to easily carry in your pocket.
    Cons
    • The blade has no half lock.
    3) Boker 111006 Pocket Lock Blade Stag Pocket Knife
    Boker is a world-famous knife maker from Germany, and they have been making stunningly beautiful hand-crafted knives for over 145 years. This pocket lock knife from Boker is no exception and it is one of the most beautiful and among the best 2 inch pocket knife models.
    Pros
    • The blade length is two inches only – you won’t even notice it in your pocket.
    • The blade is made of premium Solingen stainless steel from Germany.
    • The stag rosewood handle has a rich finish and luxurious feel to it.
    • Comes packaged in a nice box. It is perfect for a gift, souvenir or purchased as a keepsake.
    Cons
    • Did not arrive super sharp but can be sharpened easily.
    • The handle is short and will not support a four-finger grip. But we suppose it’s not designed for that.
    4) Kershaw Method Folding Pocketknife (1170) - Jens Anso Design
    This knife is designed by Jens Anso of Denmark, a world-renowned knife maker and industrial designer. This Kershaw pocket knife is built with excellent quality and stability. Adorned in an all-black color, it has a serrated edge, it is strong and the blade has a vintage look. It is one of the best small single blade pocket knife models that can make a memorable gift or souvenir.
    Pros
    • The knife has a three-inch blade which is made of 8Cr13MoV stainless-steel. While it might not be as good as high-quality AUS 8 stainless steel, type 8CR is very cheap. When ground properly it can be a winner.
    • The 10G handle is made of wood and epoxy-filled woven fiber glass, which is highly durable, can withstand high stress and temperature without major deformation. A unique 3-D machined pattern on the G10 scales provides a nice grip.
    • KVT opening system using ball bearings allows for one-hand quick opening.
    • The knife design is impressive overall, with its partial serrated edge.
    Cons
    • The flipper is a bit too small, which might cause difficulty grabbing it and flipping the blade open.
    5) Victorinox Swiss Army Multi-Tool, SwissChamp Pocket Knife
    SwissChamp pocket knife is a multi-tool that has a mind boggling 33 functions packed into the tiny 6.5 oz pocket size knife. It has almost everything you can think of: blades, screwdriver, wire stripper, tweezers, toothpick, scissors, ruler (in/cm), files, saw, chisel / scraper, pliers, magnifying lens, pressurized ballpoint pen, etc. Honestly, we lost count. Simply because of its sheer functionality, the SwissChamp pocket is one of the best mens' small pocket knife, and might as well be the best pocket knife of all time.
    Pros
    • All the tools are finely made with high-quality stainless steel, encased in their trademark polished ABS scales that look that look sleek yet durable.
    • The SwissChamp pocket knife is truly a toolbox that comfortably fits in your pocket.
    Cons
    • It might be a little too bulky for a pocket knife.
    Bottom Line
    In this review, we have looked in detail at five of the Best Rated Pocket Knife for everyday use. Both pros and cons of each knife are discussed, as well as the quality of the materials involved. They are all exceptional knives with high-quality stainless-steel, breathtaking looks, and craftsmanship of the highest level. No matter which one you prefer, we believe you can comfortably bring it with you every day and trust it to perform whenever you need it to.
