Application materials of Headstone tombstone carving cnc router machine :
Stone material: natural marble, granite, artificial stone, tombstones, stone, jade carving and processing.
Decoration categories: ceramics, crystal, glass, plastic, chemical synthetic organic glass board, PVC board, wood, plastic, metal, plastic materials, such as line carve, 2d, 3d bottom tip carving, 3d relief, cutting, edge, drilling.
Performance feature of stone cnc router :
1.Imported linear guide rail, double-row four columns ball bearings, huge bearing capacity, good moving stability, long lifetime. Imported ball-screw, high precision.
2.Adopting high-precision gear rack transmission, faster working and high precision.
3.Equipped with USB of remote operation and DSP operating system, lever operation is very simple and advanced.
4.Be compatible with several CAD/CAM designing software, type3, ARTCAM, CASTMATE, UCANCAM etc.
5.Adopting the stepper motor drives, Y axis adopts double motor drive to make the spindle engrave faster.
6.Structure:Thick square pipe welded structures, which strengthen hole lathe bed stability.
Samples show :
