586,005 active members*
5,209 visitors online*
    Issue with A-axis on Chinese Workbee Stb5100
    Just built a Workbee 1x1m and tried motor movement. Having an issue that A-axis is making loud rattling noise like GRRR. You would hear such noise if you would drag a lead screw perpendicular across a metal edge.
    System is Win10 Laptop hooked via usb motion controller Stb5100 running Motor Driver Board TB6600.
    For this I realize I need to have a manufacturer usb driver but it was not supplied. I am using a usbmach.dll I found online.
    X and Z axis motors are turning normal and moving the head. When I try to jog in Y direction A-axis (screw) is not rotating but rather oscillating turning clockwise/counterclockwise and making a loud noise. Y-axis and A-axis motors are a twin pair supporting Y dir movement of gentry. When I disconnect A-axis motor, Y-axis motor and movement works fine.
    I have made A be slave to Y. Other than non original usb driver and maybe incorrect Mach3 setup I am not sure what could be an issue here. A axis is coupled well to lead screw, and screw is moving freely when machine is powered down.
    Wondering if anybody came across anything similar?
    Jan 2007
    626
    Re: Issue with A-axis on Chinese Workbee Stb5100
    Try disconnecting the Y and A axis steppers from the ball Screws ( lead screws?) and observe how they behave. Do they turn in the correct directions and run at the same speeds?
  1. Motors won't turn but they are locked!(Workbee CNC, MACH3, Novusun Controller).Help!
    By cncnoob67 in forum Mach Software (ArtSoft software)
    Last Post: 03-29-2019, 02:09 PM
  2. OpenBuilds Workbee VS Raw CNC 1.5 VS something else?
    By chugchug in forum DIY CNC Router Table Machines
    Last Post: 02-09-2019, 09:51 AM
  3. 1st CNC Router Recommendation - Workbee vs Shapeoko vs Millright
    By TriptonPT in forum Want To Buy...Need help!
    Last Post: 01-19-2019, 08:46 AM
  4. Chinese laser cutter issue
    By ariemeir in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-04-2014, 11:24 AM
