585,763 active members*
4,069 visitors online*
Results 1 to 6 of 6
    Oct 2018
    22
    Driver On/Off
    Hi im in the phase of building a cnc machine and i have few things that are messing with me. It's not a big deal but i could not see anywhere..if you plug your machine all the steppers are going to hold/stuck my leadscew driven machine and let's say i need to move my X manually (i have dual shaft motors) i want to turn on/off my motors individually with a separate rotary knob for every motor.
    What is the most logical way to turn off a motor: cut the Power V+36 or Signal V+5 (to the driver) hmm?
    Mar 2007
    2083
    Re: Driver On/Off
    which stepper drivers are you using ?
    many have 3 inputs step , direction and enable
    the enable being unusual in being a negative logic input so the drive is enabled with no enable input !
    if you have a drive with opto-isolated inputs like this for example
    Attachment 420624
    some CNC machines don't have the stepper driver enable inputs connected
    making it easy to add switches to disable a driver
    connecting +5V via a switch to the + enable input and 0V / ground to the - enable input
    will disable the drive
    making it possible you to manualy turn the motor with the power on
    John
    Nov 2012
    1267
    Re: Driver On/Off
    Quote Originally Posted by Tazdingo View Post
    Probably the best way would be to use the ENABLE signal if your stepper driver has it (most of them do).
    Oct 2018
    22
    Re: Driver On/Off
    im using DM542A i have wire them like this: Pulse5+ and Direction5+ are feed from my 5v power supply, pulse and direction negative are connected to pin2 and pin3 on the bob. I was following the diagram from this picturehttps://www.cnczone.com/forums/attac...1&d=1558634485. And on this picture is the testing wiring https://www.cnczone.com/forums/attac...1&d=1558634485 it works like this :/
    Mar 2007
    2083
    Re: Driver On/Off
    quick diagram to dissable one axis using the stepper driver enable inputs
    Attachment 420704
    John
    Oct 2018
    22
    Re: Driver On/Off
    Thanks for your time John, you saved me a lot of time and nerves ??
  1. sla7033 stepper motor driver (unipolar driver?)
    By Emanuelg in forum Stepper Motors / Drives
    Last Post: 01-12-2017, 10:54 PM
  2. Yaskawa Servo driver CPCR-MR01C Driver problem
    By pvpatel in forum Benchtop Machines
    Last Post: 04-04-2016, 09:25 AM
  3. stepper driver using h-bridge to analog servo driver
    By aztec in forum Servo Motors / Drives
    Last Post: 02-07-2016, 06:24 PM
  4. Replies: 7
    Last Post: 01-10-2015, 05:49 PM
  5. Replacing TB6560 driver board's driver chip. Is it possible?
    By Moodaguda in forum CNC Machine Related Electronics
    Last Post: 08-07-2013, 09:02 AM
