585,996 active members*
4,222 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma lb 15 osp 5000L-G Paramter Floppy disk information
Results 1 to 7 of 7
    Apr 2015
    45
    Hello,
    we have cloned the old 16 inch floppy disk with parameters in it from ocuma lb 15 osp 5000-LG, we can't open floppy with windows, because it has different partition in it. So the question is maybe someone know how to look the information in it. We want to type parameters manually to the machine, because there is no way to get the 16 inch floppy drive to plug to the machine to load the software.
    Jun 2020
    64
    Re: Okuma lb 15 osp 5000L-G Paramter Floppy disk information
    hi, free space from your inbox, i can't send you messages, thanks
    Apr 2009
    1262
    You should have a data management card in the back of your machine that lists the machine coordinate data for your machine. Once that is entered I can provide you with the Long Word, Word, and BIT defaults.
    Your 8” floppy is in Okuma format and is encrypted so you will not be able to extract the info.
    Also check to see if you have the DATA PIP function on your machine. If you do then you may be able to transmit the data into or out of your machine by RS 232.
    Experience is what you get just after you needed it.
    Apr 2006
    111
    You must have specific software in windows or you can put it to your machine and use command to view file in your disk
    Jun 2020
    64
    Quote Originally Posted by OkumaWiz View Post
    hi how can i see if i have DATAPIP on my machine? thanks for help
    Apr 2009
    1262
    Go to Edit mode and press EXTEND several times to see if the DATA-PIP button shows up. Or else check the Management Data card to see if the option is on your machine.
    Mar 2009
    1982
    or, try key in
    DPIP
    or
    DATA-PIP
    following with <Enter> or <Write> key. The system reaction will indicate if the command is recognised or not.
  1. Floppy disk
    By KHOATRANNGOC in forum Okuma
    Last Post: 06-13-2019, 12:28 AM
  2. Floppy disk...
    By Bluegillman in forum HURCO
    Last Post: 05-25-2018, 07:13 AM
  3. Dolphin CAD on floppy disk
    By MLydon in forum Want To Buy...Need help!
    Last Post: 09-19-2016, 08:39 PM
  4. No floppy disk, only USB
    By davedaneels in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 05-13-2008, 11:37 AM
