Pipe plate special laser cutting machine works
The special laser cutting machine for tube plate is designed for the precision processing of large quantities of pipes. The professional pipe cutting equipment designed and developed according to market requirements is suitable for large-scale pipe cutting processing and has high equipment stability.
1. Feeding rack: Before the cutting starts, it is necessary to manually carry the whole bundle of pipes to the loading rack, remove them by manual packaging, and place them in multiple rows on the automatic conveying mechanism of the pipe.
2. The pipe material is placed on the conveying platform in turn, and the pipe conveying device can transfer the pipe material to the feeding mechanism every time according to the requirements, and automatically supplement the standby according to the pipe material.
3. The feeding mechanism will automatically transfer the waiting area pipe to the automatic feeding mechanism according to the signal, and the other pipes will automatically fill and move to the material position to ensure continuous operation.
4. The pipe positioning and calibration system aligns the pipe position as required (the pipe material should not be placed outside the feeding mechanism);
5. The feeding structure automatically sends the pipe to the machine tool material (lifting) shelving system according to the signal (one pipe is delivered at a time);
6. The feeding mechanism receives the shelving signal and returns it in time, and the A rotating jaw device moves according to the signal-clamping-advance to the B rotating disc for perfect cutting;
7. The material rest system automatically lifts and avoids collision according to the distance of the A rotating jaw device;
