You could phrase that as too much rubbing in the dust!
You can solve a lot of that with a continuous air blast aimed at the cutter. It will cool the cutter and clear out the swarf. Then you could probably run continuous. Downside is that you need a compressor. Plenty of us use an air blast.
Cheers
Roger
