585,722 active members*
4,039 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > Replacing lead screws with 8mm lead in 2418 machine.
Results 1 to 2 of 2
    May 2019
    Hi. I have replaced all lead screws with new 8mm leads. Now the machine is producing distorted cuts, i think from the Y axis.
    As I am a complete novice at this, could you give me some idiot proof advice?
    I am using GRBL 0.9 controller.
    Jan 2007
    626
    Re: Replacing lead screws with 8mm lead in 2418 machine.
    It sounds like the pitch of the new lead screws is different to the originals.
    I assume you have seen this?
    https://github.com/grbl/grbl/wiki/Configuring-Grbl-v0.9
    I don't use GRBL so can't help much.
    Looks like you can list all your settings. Note them down before you change anything.
    I'd start by entering as command to move the Y axis a specific distance and then measure the actual distance moved with a steel rule.
    Use that info to change your stepper parameters so they match.
    Make one change at a time and see what happens.
  1. Lead screws?
    By lgroulx200 in forum Momus Design CNC plans
    Last Post: 09-06-2013, 11:52 PM
  2. Replacing lead screw nut on z-axis
    By pjskyguy in forum Taig Mills / Lathes
    Last Post: 07-27-2012, 09:34 PM
  3. Regular ACME Lead Screws Vs Precision Screws?
    By FreshMint in forum DIY CNC Router Table Machines
    Last Post: 11-27-2011, 03:51 PM
  4. lead screws
    By Runner4404spd in forum Uncategorised MetalWorking Machines
    Last Post: 02-08-2008, 03:36 AM
  5. Lead Screws
    By mdframe in forum DIY CNC Router Table Machines
    Last Post: 03-22-2004, 03:20 AM
