586,000 active members*
4,926 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Thread cycle command
    Aug 2011
    419
    Hi
    What is the difference between G31 and G33?
    "Imagination is more important than knowledge."
    Apr 2009
    1262
    Re: Thread cycle command
    G33 can do continuous coordinates so multiple x-z coordinates can be used. This makes possible such things as oil ring grooves using threading style passes.
    Best regards,
    Experience is what you get just after you needed it.
    Jun 2015
    4154
    hello again, continuous mode is possible under 34; about 33 & 31, i believe that 31 was available on older osp generations, maybe capable only on longitudinal threading, while newer ones started to use 33
    kurmay, do you really care about finding a difference ? kindly
  1. One Line G76 Thread Cycle
    By Dave Wojo in forum Fanuc
    Last Post: 07-24-2018, 02:21 PM
  2. G92 thread cycle
    By AE81 in forum CNC Swiss Screw Machines
    Last Post: 02-22-2017, 07:16 PM
  3. Replies: 1
    Last Post: 09-18-2014, 09:57 PM
  4. g76 thread cycle
    By warcnc in forum G-Code Programing
    Last Post: 02-03-2013, 11:32 PM
  5. G76 Thread Cycle
    By eliot15 in forum G-Code Programing
    Last Post: 03-27-2011, 04:01 PM
