585,906 active members*
3,739 visitors online*
IndustryArena Forum > CAM Software > Surfcam > Getting CSYS data from Surfcam
    May 2012
    100
    Is it possible to make a Posthaste post for Surfcam, (Postform) that takes the Ccys data from a 4-axis operation and
    puts all the offsets values G54-59 (however many offsets used in the file) automatically with the right values, from the machine zero in B-center?
    This can be done with advanced post processors with other cam systems, like Gibbscam and Mastercam. Probably with Surfcam to, but
    i wonder if it can be done with Posthaste. Buying a postprocessor is not an option, to expensive. We have no license anymore.
    Feb 2006
    49
    Re: Getting CSYS data from Surfcam
    yes it can you need to mod the post in both the tool change area and the between area. you can do g54 or g54.1p1 2 3 4 5 99 etc
  1. Replies: 4
    Last Post: 11-18-2016, 11:47 PM
  2. Replies: 0
    Last Post: 12-16-2014, 05:17 AM
  3. Surfcam, Inc. Releases SURFCAM 2014 R2
    By forjaco in forum Surfcam
    Last Post: 04-22-2014, 10:12 AM
  4. ascii data filtering using Surfcam?
    By casey in forum Uncategorised CAM Discussion
    Last Post: 05-15-2007, 01:57 AM
  5. ascii data filtering using Surfcam
    By casey in forum Surfcam
    Last Post: 04-25-2007, 02:33 AM
