586,024 active members*
4,176 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Conversational DXF Import
Results 1 to 9 of 9
    Mar 2016
    25
    Was going to try out the dxf import into a conversational program today by using the F9/cad key then F1 mill. When I select mill it goes to the next screen and says "unsupported screen". Guessing I need a parameter change somewhere?
    Re: Conversational DXF Import
    Hi MontyNTenon, did you have the chance to fix this problem?, because we have the same problem after clicking this F9CAD> F1MILL or F2DRILL. our main panel shows "screen unsupported". we have a centurion 6 controls.
    Mar 2016
    25
    Quote Originally Posted by Pogi_pura View Post
    My mill has the SLS version of C6. I'm guessing that's why it doesn't work but I don't know for sure. I never did get it to work.
    We have the same control, it is SLS version of Centurion 6 in MB20 Milltronics mill. 3axis SLS CNC 6.3141 FLASH based from the system info i got. this is bad news for us. Do you have any idea which i can import a cad from SLS version? Thanks in advance
    i mean any other idea.. very much appreciated sir!
    Mar 2016
    25
    Have you tried emailing Milltronics?
    Apr 2008
    21
    I have a pdf of the sls manual. It doesn't say much about dxf files but...
    Under the parameter settings you can change the CAD type to dxf or CDL for imported files.
    Maybe it's as easy as switching that?
    Mar 2016
    25
    I have it set for dxf but it won't even get to the point of a picking a file.
    Morty, Not yet but i am guessing that SLS version has a restrictions compare to a regular program. Looks like there is a port at the side of the panel and it is an old port for the keyboard. are you guys using this? and there is a floppy disk and a RS232 port at the back side of the machine. Can we connect a laptop here and access the drive and the program and work on the laptop although it is an SLS type of version. I am asking this question because maybe i bought the cables and stuff but will not work since it has an SLS? Thank you guys for the reply
  1. Conversational CAM
    By ZeroBacklash in forum Uncategorised CAM Discussion
    Last Post: 10-24-2018, 09:40 AM
  2. Conversational G53 has no G0.. what's up with that???
    By SoCalPlaneDoc in forum Tormach PathPilot™
    Last Post: 08-25-2016, 08:52 PM
  3. Chuck Arbors - Import or...Import?!
    By scorpion in forum MetalWork Discussion
    Last Post: 10-23-2012, 07:08 PM
  4. Replies: 10
    Last Post: 12-29-2008, 10:35 PM
