586,011 active members*
4,374 visitors online*
IndustryArena Forum > CAM Software > CutLeader > postprocessor for laser machine with cypcut control
Results 1 to 8 of 8
    Sep 2011
    110
    Post postprocessor for laser machine with cypcut control
    Cypcut is widely used as laser control/software similar than the start control for plasma machine.
    The software works with the control (online cam software) is convenient for small size order. Some of machine owner likes to have offline programming in order to get more efficient running.
    The cypcut accepts NC file (G-Code) but the laser technical info in the NC code would be lost, because cypcut would convert the NC file to CAD drawing and assign cam feature to the geometry again.
    The file format saved by cypcut is in extension *.lxd, which is a file in XML style. We cost much time to investigate the content of the lxd file, and developed a postprocessor for it successfully. In this way, the cutting layer/leadinout/marking/ info did in CutLeader could be pass to cypcut without losing of cam information.
    Sep 2011
    110
    Re: postprocessor for laser machine with cypcut control
    We made a software to convert multiple dxf layout files to LXD file, then user could run the cutting in more efficiently, with less machine stop time.
    Attachment 423780
    Sep 2011
    110
    Other than converting DXF file to LXD for cypcut software, it is possible now to convert NC files to one lxd file for cypcut.
    It is very useful then client has one more machine with different brand, user could convert the G code file for traditional CNC machine to LXD file for the machine with Cypcut software.
    This tool could be enahnced to convert G code file from one format to other format also, or reverse the G code to DXF file.
    Attachment 432694
    Sep 2014
    Quote Originally Posted by cutleader View Post
    I have a Leiming LM3015H Laser. I would like to get a trial version of CypNest to do offline nesting. Can you help me with that?
    Thanks Brian
    Sep 2011
    110
    Sorry for late reply.
    Would you check if Cypcut software is equiped in the machine.
    As I think the Cypnest isn't free, it is charged annually.
    Here is the download link of the Cypnest package in their website:
    http://admin.fscut.com/file/20200116...t6.3.782.0.exe
    Cutleader/NestClient could help you also if you are interested in the offline nesting,
    Dec 2020
    https://d.fscut.com/wordpress-fscut/...t6.3.781.8.exe
    ou a versão CypNest6.3.781.8.exe (6.3.781.8)
    estou precisando deste instalativo.
    **gt**
    or version CypNest6.3.781.8.exe (6.3.781.8)
    I need this installation.
    Dec 2020
    Tell us more about your conversion software, do you have a demo?
    Nov 2010
    Hi Guys, is there any possibility to covert the nesting file from ncp/lcc to lxd ?
    we have a Bystronic laser cut which is using ncp/lcc nesting format to communicate with the machine, my boss was bought a China Hong Shan LKaser cut machine recently but the are using lxd format to communicate with the machine, my question
  1. postprocessor for START/ FANGLING control
    By cutleader in forum CutLeader
    Last Post: 02-25-2020, 03:47 AM
  2. Where can I buy laser power control board for 40w MoshiDraw laser machine
    By azit in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-02-2016, 09:48 PM
  3. Replies: 0
    Last Post: 01-15-2016, 08:38 AM
  4. 18How to control the laser machine from the software
    By thunderlaser in forum Laser Control Software
    Last Post: 12-11-2013, 09:21 AM
  5. Lathe Postprocessor for Siemens Control
    By mecheng10 in forum SprutCAM
    Last Post: 11-10-2012, 05:19 PM
