586,009 active members*
4,826 visitors online*
    May 2019
    TopWisdom Ruida swap question
    Bought a Redsail X700 off eBay. Trying to swap the TL-403CB Topwisdom controller it came with to a Ruida RDC6442S and I came across a problem. The TL only had one line for X origin limit and another for Y origin limit (IN-5 & IN-3). The Ruida has an Y+ And Y- and X+ and X- (two input slots for each). Which ones do I plug into?
    Attached Thumbnails Attached Thumbnails 50951453-B149-4A0F-AFCD-5BA8921A7042.jpg
    May 2019
    See other picture
    Attached Thumbnails Attached Thumbnails 059BCE9B-DFFF-4BC3-B7E9-FDE86FB89935.jpg
    Nov 2008
    644
    Re: TopWisdom Ruida swap question
    I would either put both limits of the same axis on that axis or only put the switch that it homes too. The controller knows that it’s moving the Y axis and either switch will stop it. I don’t use the far limit switches because Your cam software or controller stops it from hitting that limit.
    Oct 2015
    sorry to resurrect this thread, but i am doing the same swap...I am wondering what you did with the power inputs...mine has 2, external and internal, the ruida has one. Looks like i will need a new power supply.
