Hello to all,
I have one problem. We bought a used CNC lathe DMC Q6 with FANUC Oi mate-TD controller.
The feedrate override potenciometer is not working properly. When I am in jog mode or if it is in program G01 code is working normally. When potenciometer is on 0% it doesn't move and when I increasing it it is moving proportionally with percentage.
But when I have in code G00, on 0% it doesn't move and when I raise it up on 10% it goes with 100% speed.
I have a question if there is any parameter in that I have to change it or is there any other trick?
I already checked the parameter#1401 and it is OK.
The odd thing is, that we have one more CNC lathe DMC but older also with FANUC Oi mate-TC and it is working right.
On lathe we have a clamping device and it is very risky to work with 100% rapid move.
Second problem is handle wheel which it doesn't work at all. Is there also enable/disable function in parameters or it is just broken?
Thank you in advance for your answers.
GasperStef
