585,708 active members*
3,855 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > FANUC Oi MATE-TD feedrate ovverride and handle not working
    Nov 2014
    Hello to all,
    I have one problem. We bought a used CNC lathe DMC Q6 with FANUC Oi mate-TD controller.
    The feedrate override potenciometer is not working properly. When I am in jog mode or if it is in program G01 code is working normally. When potenciometer is on 0% it doesn't move and when I increasing it it is moving proportionally with percentage.
    But when I have in code G00, on 0% it doesn't move and when I raise it up on 10% it goes with 100% speed.
    I have a question if there is any parameter in that I have to change it or is there any other trick?
    I already checked the parameter#1401 and it is OK.
    The odd thing is, that we have one more CNC lathe DMC but older also with FANUC Oi mate-TC and it is working right.
    On lathe we have a clamping device and it is very risky to work with 100% rapid move.
    Second problem is handle wheel which it doesn't work at all. Is there also enable/disable function in parameters or it is just broken?
    Thank you in advance for your answers.
    GasperStef
    Dec 2009
    952
    Re: FANUC Oi MATE-TD feedrate ovverride and handle not working
    you should have 2 potenciometers,one for jog feedrate with 12 positions from 0 to 120% and one for rapid move with 4 positions from 0-25-50-100%
    if it is movinfg at 100% when you put the jog feedrate at 10% it means that the rapid feedrate potenciometer is on 100% and it is normal when G00 is executed,G01 it is holded by jog feedrate and G00 is holded on another potentiometer
    a picture with the operator panel should be clear for us.
    thank you
    Feb 2009
    6028
    I agree a picture would help, if the op panel is a builder made one, my guess is you have a broken 5VDC wire in the back.
    You will have to look in the ladder to understand how the rapid over ride on your machine functions.
  1. Feedrate Override Pot not working on Fanuc O-M
    By jamesgates1000 in forum Fanuc
    Last Post: 02-05-2023, 11:28 AM
  2. Replies: 4
    Last Post: 01-23-2022, 05:45 AM
  3. MPG Handle problem - Fanuc Series Oi-MB
    By PlasmaManZA in forum Fanuc
    Last Post: 04-30-2018, 08:09 PM
  4. Combined straight handle and t-handle tap wrench!
    By northernmach in forum News Announcements
    Last Post: 08-20-2016, 02:32 AM
  5. Wasino Lathe with Fanuc 3T Feedrate is Zero
    By Brinmetal in forum Fanuc
    Last Post: 06-10-2016, 04:38 AM
