585,974 active members*
4,338 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > How is everyone building a DIY CNC router system that maintains cutting tolerances?
Page 7 of 7 567
Results 121 to 122 of 122
  1. #121
    Oct 2004
    94
    Quote Originally Posted by JFL4066 View Post
    It would be an interesting exercise to have everyone load a given set of G code for a square or whatever and have them cut it on their machine. Measure the end result and publish the results.
    Even better - have the part sent out to the same lab for measurement.
  2. #122
    Mar 2017
    926
    Re: How is everyone building a DIY CNC router system that maintains cutting tolerance
    Given the complexity in the factors that contribute towards accuracy (or inaccuracy), I doubt such a test would tell us anything conclusive. Even if everyone was cutting the same wood from the same batch with the same water content and using the same end mills, the different climates would alter the results.
    If tests were limited to aluminum, some routers might not be sufficiently stiff or have decent enough vibration damping which would throw off the results. A machine could be accurate for one job but not the next.
    Plus, we'd still have the main issue which is measuring it consistently from one user to the next. The machine builder is hardly an impartial judge and the results with cheap ebay calipers and gauges can be manipulated. I struggle to get the same results if I measure the same part twice with my calipers. And forget about those cheap ebay gauge arms. A stiff sneeze changes the reading with those things. And... People lie on the internet.
    Measuring cnc accuracy is like taking a selfie. We can all take a good one with the right lighting but our friends camera then adds 10lb...
Page 7 of 7 567
  1. Building a cnc router cabable of cutting aluminium
    By ahtopahtel in forum DIY CNC Router Table Machines
    Last Post: 05-30-2019, 10:36 AM
  2. Anyone building Plate Marker system?
    By Sperstad in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 08-20-2012, 11:53 AM
  3. building the table with exhaustion system
    By Alex S.A in forum Waterjet General Topics
    Last Post: 01-11-2007, 03:34 AM
  4. My New Custom System I am building.
    By WallCrawler in forum Computers / Desktops / Networking
    Last Post: 12-09-2004, 02:31 AM
