585,991 active members*
4,574 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > squeaky chinese spindle.
    Jun 2012
    153
    Hi, I am just powering up the spindle for the first time on my self-designed CNC milling machine.
    I bought a 2kW water-cooled, chinese VFS and spindle. I have a provisional clamping and water cct filled but not pumping.
    I ran up for about 20s to 50Hz max ( 3000 rpm ) , just enough time to attain control speed and power off again. On stopping I notice a dry squeaky noise. I suspected my clamping maybe distorting the body so slackened right off. Still there.
    These have pretty low runout spec and ( allegedly ) german bearings, so fairly tight.
    I wondered if anyone with experience of these spindles can tell me whether it is normal and well run-in , or if I have a problem.
    I did a quick video of a quick stop/start. The squeak is heard at beginning and end.
    TIA.
    http://www.solaire-chauffe-eau.info/cnc/00008.mp4
    BTW Firefox internal player seems not to produce the audio. Save and view with VLC or similar if that happens
    Sep 2005
    1740
    Re: squeaky chinese spindle.
    Quote Originally Posted by reg.miller View Post
    TIA.
    If this is a 400 Hz spindle running of a VFD, running it at less than 100 Hz is going to risk burning it out. Chinese spindle, sounds like you have issues with the bearings.... sent it back!!
    I don't think that's squeaking. Run it at 10,000 and see what it sounds like.
    What's the carrier frequency set to?
    Jun 2012
    153
    @wmgeorge:
    sorry, looking back what I wrote was incorrect. 50Hz was the minimum starting freq. , it stabilised at 400Hz.
    Thanks Gerry, I'll check tomorrow. The workshop is shut now.
    It seems perfectly free and smooth in both directions when I spin it by hand, no noise. I may need to increase the minimum speed too. After a quick perusal, I more or less kept the defaults of the VFD ( supplied with the motor ) just to test it powered on. I need to wire the pump up before I run it longer.
  1. Squeaky Servo
    By rwskinner in forum Fadal
    Last Post: 12-30-2018, 07:50 PM
  2. Replies: 3
    Last Post: 10-19-2018, 05:12 PM
  3. Mini Mill X2 Spindle Head + VFD + Chinese Spindle= custom!
    By diyengineer in forum Uncategorised MetalWorking Machines
    Last Post: 12-26-2016, 10:04 PM
  4. CHINESE SPINDLE 2.2KW
    By Ed Williams in forum Open Source CNC Machine Designs
    Last Post: 03-29-2016, 04:07 PM
  5. squeaky X axis on a Bridgeport Interact 2
    By ichudov in forum Bridgeport / Hardinge Mills
    Last Post: 08-04-2010, 06:38 AM
