Small jewelry part die set needed.
Requirements: must be able to do HIGH QUALITY 3D ENGRAVING WITH DEPTHS TO 12mm.
I have a pdf of the SIMPLE die set
it is designed on the KISS theory.
Die set is made on 2 inch round d2, a2 or s7 steel.
female die & male die have the same engraving
there is a nesting/resting area on the female die to hold the
round material disc.
I supply a HIGH DETAILED QUALITY STL FILE FOR THE ENGRAVING.....
engraving would be 12mm in diameter & 6mm depth for the first die set.
I HAVE A PDF FILE FOR THE DIE SET.......too large file here to load
can email you the file to view.
If anyone knows of a person or company capable of doing this please
let me know [email protected]
