When i run a laser program with multiple parts in it , the first part cuts at the feed rate I entered in v29 . When it goes to the next part , it doubles the feed rate speed - maybe more, when i look at the g code , only the first part has a G 01 command at the F command line . All other parts routines are missing that command , on the Feed rate line , when i manually add the g01 to each part , it works fine .
Ed
