585,744 active members*
4,378 visitors online*
IndustryArena Forum > CAM Software > EnRoute > How smart is Enroute at finding the fight tool number for multi tool strategy
    Jul 2014
    215
    Hi all, I am new to Enroute and so far am not liking the software very much. Though it has some awesome tools.
    This is my question. We have a MultiCAM 1000 with a 9 tool changer. We have the tools defined under the machine settings dialogue box.
    But when I programmed a strategy with two different tools from the default tool library it did not seem to assign different tool numbers in the code. Was this because Enroute is not that smart in making a substitute assignment from the tools defined in the machine settings. Or do I need to create a custom tool library that has an exact copy of all of the tools which are in the machine setup tools so that Enroute can properly assign the tool numbers for the strategy.
    For a time we had the tools removed from the tool changer but they were still defined in Enroute in the machine tool settings. We were dropping tools due to other problems which we have sinced fixed. Does Enroute talk so much to the controller that it knows when and if the tools are actually in the holders. Assuming the Multicam controller software had the holder defined as not having tools there.
    Also, there did not seem, or maybe I missed it, a place to define the tool number in the custom tool library in Enroute.
    Re: How smart is Enroute at finding the fight tool number for multi tool strategy
    Never used Enroute, but you most likely need to enter the tool numbers in Enroute. Most if not all CAM software works that way.
    Jul 2014
    215
    There does not seem to be a place to do it in the custom tool library. It is only in the machine setup. The other cam software that I have used usually defines the tool number in the tool library. Now that we have the tools back in the tool changer I will be experimenting more.
    Quote Originally Posted by Hezz View Post
    No, Enroute can not know what tools are in the machine automatically. It can not "talk to the machine" to query what tools are there. You have to manually set what tools are loaded in the tool changer and their positions in the machine setup windows in Enroute.
  1. Replies: 7
    Last Post: 06-26-2015, 02:15 AM
  2. Replies: 1
    Last Post: 09-21-2012, 08:21 PM
  3. Tool numbering strategy?
    By Spinnetti in forum Tormach Personal CNC Mill
    Last Post: 09-21-2012, 02:22 PM
  4. Finding spindle tool number on Fanuc OiMD
    By yaji63 in forum G-Code Programing
    Last Post: 09-17-2012, 11:12 AM
  5. Locking the tool pockets to a tool number
    By KevinV_MEI in forum Bridgeport / Hardinge Mills
    Last Post: 09-18-2011, 05:55 PM
