586,019 active members*
3,777 visitors online*
Results 1 to 7 of 7
    Nov 2005
    77
    G Code to continuous run fourth axis in the back ground
    Can anyone give me an idea how i program a fourth axis to run continuously in the back ground as my g code runs
    Re: G Code to continuous run fourth axis in the back ground
    You could configure it as a spindle, but then you'd need to control your regular spindle manually.
    Nov 2005
    77
    Is that easy to do?
    Apr 2004
    5737
    You might try detaching the 4th axis from your system and powering it separately. Sherline sells an autonomous rotary table that doesn't need a computer to run: https://www.sherline.com/product/870...table-indexer/ I don't think it has a "continuous" mode, but you could, for instance, tell it to go to 360,000 if you wanted it to rotate a thousand times.
    Andrew Werby
    Website
    Nov 2005
    77
    Thanks all I think i got it worked out in the G code. Not quite how i was hoping but it will do.
    Jun 2010
    4256
    Normally I let Mach3 drive the 4th axis with Step/Dir signals, but sometimes I want the 4th axis to behave like a lathe. So ...
    I use a single Mach3 output pin to switch between the Step/Dir pins and an external free-running oscillator and a direction switch. The latter does not require any effort from Mach3, and can be invoked from within a program. This works fine.
    However, switching back from 'lathe mode' to controlled mode is more difficult if I want to return to the original orientation. I would need to write a macro to keep stepping until the Index pulse was asserted, and to then zero the A axis. (This is possible.) So far I have avoided this need.
    Cheers
    Roger
    Aug 2019
  1. DXF to g-code generator with continuous cutting?
    By riahc3 in forum Waterjet General Topics
    Last Post: 11-05-2015, 07:30 PM
  2. C axis normalcy? Fagor Gcode sample- for continuous path jig grinding? How to code?
    By nate in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-17-2014, 07:09 PM
  3. Replies: 7
    Last Post: 12-20-2011, 07:53 PM
  4. how to get rid of the back ground code?
    By dingo0722 in forum Haas Mills
    Last Post: 10-19-2011, 04:04 PM
  5. back ground color
    By 1234567 in forum BobCad-Cam
    Last Post: 12-22-2009, 04:00 PM
