585,605 active members*
3,349 visitors online*
    Aug 2005
    29
    complex threading on 828d
    One of the things my company specializes in is complex threading. We've had great success doing that using FANUC's controls
    Recently we acquired a large flat bed lathe with an 828D control. My though process was that if I like Heidenhain ( one running one of our boring mills) Sinumeric can't be that far off.
    Now im stuck, as im trying to machine a rope groove on a large cable drum, and it seems nothing is working.
    The CYCLE 99 is great, but seems to follow just the center of the rope groove path. Shifting both X and Z-start ( as I would do on a G code machine) isn't working.
    I need to code several lines of different X and Z starts to profile the large R0.5468 groove.
    The control isn't able to read the G76 properly either, hence i cant use it
    Here's an example of the SINUMERIC code:
    CYCLE99(0.2667,51.504,-41.5,,0,0.3,0.5468,0,0,-70,1,0,1.2,1210201,4,0.5,0.547,0.5,0,0,1,0,0,3,,,, 2,1001)
    CYCLE99(-0.2667,51.504,-41.5,,0,0.3,0.5468,0,0,-70,1,0,1.2,1210201,4,0.5,0.547,0.5,0,0,1,0,0,3,,,, 2,1001)
    CYCLE99(0.2608,51.484,-41.5,,0,0.3,0.5468,0,0,-70,1,0,1.2,1210201,4,0.5,0.547,0.5,0,0,1,0,0,3,,,, 2,1001)
    CYCLE99(-0.2608,51.484,-41.5,,0,0.3,0.5468,0,0,-70,1,0,1.2,1210201,4,0.5,0.547,0.5,0,0,1,0,0,3,,,, 2,1001)
    CYCLE99(0.2543,51.464,-41.5,,0,0.3,0.5468,0,0,-70,1,0,1.2,1210201,4,0.5,0.547,0.5,0,0,1,0,0,3,,,, 2,1001)
    CYCLE99(-0.2543,51.464,-41.5,,0,0.3,0.5468,0,0,-70,1,0,1.2,1210201,4,0.5,0.547,0.5,0,0,1,0,0,3,,,, 2,1001)
    THis is what I'd do coding in G76:
    ; pass #1
    G00 X52.6 Z+.4971
    G76 P010100 Q00 R00
    G76 X51.07 W-5 R0 P6000 Q6000 F1.2
    ; pass #2
    G00 X52.6 Z-.4971
    G76 P010100 Q00 R00
    ; pass #3
    G00 X52.6 Z+.473
    G76 P010100 Q00 R00
    G76 X51.05 W-5 R0 P6000 Q6000 F1.2
    ; pass #4
    G00 X52.6 Z-.473
    G76 P010100 Q00 R00
    ; ….AND SO ON , as many times as I need to complete the profile
    Any help would be greatly appreciated ,
    Peter
    Aug 2005
    29
    Re: complex threading on 828d
    ...BUMP...
  1. Replies: 2
    Last Post: 04-11-2019, 05:40 PM
  2. THREADING: How to add threading parameters to the Init file?
    By jeffserv in forum Dynomotion/Kflop/Kanalog
    Last Post: 03-22-2015, 06:50 PM
  3. New 828D with outdated S7-200
    By pepp-eric in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 09-17-2009, 07:29 PM
