585,978 active members*
4,564 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Xzero CNC > A predator / raptor / mini mod tease
    Jun 2007
    3891
    Not assembled yet, so I'm just gonna show a little tease of the predator version here.
    Basically, I've replaced the extrusions on my predator and mini raptor with solid bar
    I made the predator ones extra short at 670mm for my machine to give me 400mm/16" travel - guitar maker size.
    the gantry cross bar is also replaced with solid.
    The mini is the same, just smaller.
    If anyone would want this type of upgrade, message me. I want to see if its worth machining a little batch of them. I can make them up to 970mm long.
    Note: you may need more x axis motor power... and maybe a stronger table to put it on
    Jun 2007
    3891
    Re: A predator / raptor / mini mod tease
    Almost ready to wire up
    Its a good 500lbs now, all in. not counting whatever i have to stick it on top of.
  1. X zero mini Raptor
    By mike2768 in forum Commercial CNC Wood Routers
    Last Post: 05-02-2016, 06:59 PM
