585,749 active members*
3,819 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > 4th axis on Z setup ??
    Oct 2009
    51
    I have been trying to set-up the 4th axis on the Z axis (i.e pointing vertically at the spindle) with intended movement being Z and 4th axis only .... but have been having issues. The program seems to create the tool path correctly but when going to simulation the stock is always orientated on the X axis direction. I have tried multiple machine definition setups, stock direction setups and multi-axis posting options (including - force table rotation) and nothing seems to correct he problem. Posting results in a program with no movement in any axis.
    Its not imperative to make the machine work this way but am told in can be done. The application is simply a multiple hole pattern in a circular disk and with (mainly) only Z and 4th movement will result in a smaller/simple post. Bobcad is V31 4th axis standard ... (at last much more user friendly than the old versions).
    Am probably missing a simple set somewhere ... can anyone point me in the right direction ??
    Jun 2010
    4256
    Re: 4th axis on Z setup ??
    A axis is along the X axis, B axis is along the Y axis, and the rarely used C axis is along the Z axis.
    In any event, there are much simpler and better ways to machine a ring of holes using a short program.
    Cheers
    Roger
  1. Replies: 19
    Last Post: 06-07-2016, 05:54 AM
  2. Y-Axis / Z-Axis Bearing Setup Question
    By KittyPants in forum DIY CNC Router Table Machines
    Last Post: 08-22-2013, 10:45 AM
  3. Wanted: 4/5" pre-made Z axis for 3 axis setup
    By telmnstr in forum Want To Buy...Need help!
    Last Post: 05-14-2012, 09:52 PM
  4. Mach3 A axis (4th axis) setup?
    By cadcamslawek in forum Mach Software (ArtSoft software)
    Last Post: 01-18-2012, 03:23 AM
  5. Replies: 1
    Last Post: 07-26-2011, 11:28 AM
