585,977 active members*
4,486 visitors online*
IndustryArena Forum > Mechanical Engineering > Mechanical Calculations/Engineering Design > Sinumerik 810T NC Alarm 2000 Ord 1 Emergency Stop
Results 1 to 1 of 1
    Feb 2016
    28
    I got emco lathe with sinumerik 810T GA3. It was working fine and suddenly it stopped i got nc alarm 2000 ord 1 Emergency stop. I checked PLC alarms you can see it in attached file. I cant figure out what is wrong.
    I checked electrical scheme and i didnt find nothing wrong.
    i checked manual and i found that i should check ladder diagram for output Q78.1 but i cant find where to check it. I dont have much experiance with sinumerik 810 maybe somebody could help with advices where could be the problem or what else should i check.
    Thank you.
    Attached Thumbnails Attached Thumbnails viber image 2019-06-05 , 21.36.44.jpg
  1. ALARM 20 NMI EMERGENCY STOP.
    By GPena in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-13-2022, 02:48 PM
  2. NMI 20 Emergency Stop Alarm
    By pcreek in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-17-2019, 01:52 PM
  3. Alarm 20 NMI emergency stop and alarm 204 spindle controller malfunction
    By bdrotaru in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-25-2019, 04:36 PM
  4. Nmi emergency stop alarm
    By richalex in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-06-2015, 05:43 PM
  5. Alarm 128 QT-8 Emergency stop
    By grabolo in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-22-2009, 07:24 PM
