585,981 active members*
4,582 visitors online*
Page 3 of 3 123
Results 41 to 42 of 42
  1. #41
    ericks Guest
    Re: Upgrade/repairs
    Quote Originally Posted by ropewrench View Post
    Hope the owner comes through
    I started downsizing my plans 4x4 eats up to much space
    i really don't need it that big and if i do i will go see my buddy down the road
    best of luck
    Kelly
    3 by 3 or rails and screws that fall within range
    the one foot gives me working room
    i need a bigger shop or less stuff " Hobbies, Projects, Repairs some might call them "get to them later stuff""
    I am leaning toward the G540
    I just received an ESS Ethernet to connect to my Hobbycnc chopper board so I can run Windows 10
    My lpt port is out on my xp box and its slow and old
    I am planning to run the G540 with it when I upgrade.
    with new motors, power and spindle.
    Your work has been inspiring
    He basically have to cause i have his machine
    The G540 seem to be a good unit, i just ordered one today, need to make up a pcb for faster connecting of wiring.
    This machine i am working on still runs of the printer port, he's bringing it around for me to sort cause he could not get it to work.
    I think i will modify his panel so that he has the option to do a quick upgrade to a motion controller if required.
    Thanks for the compliment
  2. #42
    ericks Guest
    Re: Upgrade/repairs
    No work done on the mechanical....however there will be some changes to the control box. Reason for this is electrical safety and cost. I was going to have dual IEC filtered supply point/sockets due to the VFD in the box. This would have meant a four pole panel mount isolator would be required. In the photo i temporarily installed a three pole. After some testing i have decided to use a single 20A IEC filtered socket to supply everything in the panel. Thus the existing isolator is fine....Also the gland plate entries will change and some of the wiring, i did this to allow for easy upgrading. The HY drive will be replaced with a more compact 2.2KW drive. This will free up space for other bits, he is already talking about a fourth axis, so i will add a leadshine drive
Page 3 of 3 123
  1. 6040 repairs/service
    By ericks in forum Chinese Machines
    Last Post: 04-09-2019, 07:29 AM
  2. A2100 control repairs
    By supraman in forum Cincinnati CNC
    Last Post: 07-16-2015, 04:42 AM
  3. Servotron board repairs
    By peterwalker58 in forum Servo Motors / Drives
    Last Post: 07-16-2013, 10:21 AM
  4. PLC center for repairs?
    By Lasershop in forum Bridgeport / Hardinge Mills
    Last Post: 12-10-2005, 06:48 PM
