585,991 active members*
4,725 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Control Software > Use co2 laser machine controll card to controll 30W fiber source
    Aug 2005
    108
    Hi all,
    i have two 30W fiber laser source from marking machines, IPG and Raycus , i want to install the fiber dource on a small co2 laser cutting machine. The machine use a Ph card, similar to Ruida . Have a way to controll the fiber source using this card? I need only to controll fire laser and power. Or maybe use the card to fire laser and something like analogic simple circuit to set power manually
    Jun 2015
    Ruida controller doesn’t allow to operate with galvo scan head. So you can’t.
    May 2020
    Re: Use co2 laser machine controll card to controll 30W fiber source
    Hi, EZCAD2 seems to be the best solution.
  1. Single axis controll using SD card and MK3
    By harryn in forum PlanetCNC
    Last Post: 08-21-2018, 03:42 PM
  2. Replies: 1
    Last Post: 08-15-2018, 04:34 PM
  3. Best controll board for 40w china laser, grayscale/ 3d?
    By monkeyfist in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-01-2015, 08:06 PM
  4. C code for CNC machine controll
    By stan2323 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-27-2008, 03:12 AM
