585,974 active members*
4,263 visitors online*
Results 1 to 6 of 6
    Raising and lowering the bed
    Hi all,
    I recently purchased a new cheap 60W Chinese laser cutter, and the up and down buttons aren't working. I'm pretty sure the reason they aren't working is because they are missing
    My question...since I don't know how long it will take to get a new control panel (one that at least sort of matches the eBay picture), is there a way to raise and lower the bed using software? For example, can I use laserdrw? I've searched through posts, and it seems most issues are because the buttons don't work, not because they are missing.
    Thanks!
    Board: 6C6879-LASER-M2
    Fireware (hoping they meant firmware): 2018.06.18
    Mar 2016
    94
    Re: Raising and lowering the bed
    hi
    NO you wont control anything in laserdrw
    Dave
    Is there a knob at one of the corners of the bed? You may not even have a motor for raising & lowering the bed. Check to see if there is a motor. You were either shipped the wrong machine all together or, the wrong photo was posted for the ad. Verify the info.
    Sent from my SM-G935F using Tapatalk
    Aug 2018
    28
    Hi Rick,
    Is there a screw in any of the corners of the work table? Normally in this type of machines height regulation is manual.
    Could you send more photos of the machine?
    Does the machine have screws for the table to go up or down?
    Best regards,
    I am an experienced laser technician.
    User of laser cutting machine Buchicnc EVO 14.
    User of laser recorder EVO 5.
    CNC router user, with 3 x 2 m table Auto Tool Changer
    I design my own laser files designs for laser cutter & laser engraver with CorelDraw, LaserCut 5.3, RDWorks V8.
    Laser cutters & CNC Routers BuchiCNC USA
    CNC Router ATC
    EVO 14
    Quote Originally Posted by TokinSpokane View Post
    Yes, the machine has a motor connected to a chain that encircles the 4 corner threaded rods. I was able to contact the seller, and they said I received the new design. This design has a toggle switch on the side for moving the bed up and down. Unfortunately, the motor only works in one direction, so they are sending me a new motor.
    Quote Originally Posted by germanr View Post
    Hi Rick,
    I'm attaching more pics of the machine. Apparently, the toggle switch on the side is supposed to control the height-adjustment motor. The bad news is that the center point of the switch is extremely finicky, so the slightest bump activates the lifting of the bed. I ordered a pair of momentary switches, and they are working much better. Now I just have to wait for the new motor they're sending me since the existing motor only works in one direction.
  1. Help with my Z raising during 3d carving
    By KurtRosenzweig in forum Chinese Machines
    Last Post: 06-14-2018, 03:46 PM
  2. Z AXIS raising up
    By i_am_joe in forum Uncategorised WoodWorking Machines
    Last Post: 04-27-2012, 10:51 PM
  3. Raising up a vise
    By webgeek in forum MetalWork Discussion
    Last Post: 11-08-2010, 03:49 AM
  4. Raising Taig headstock
    By MechanoMan in forum Taig Mills / Lathes
    Last Post: 04-14-2009, 10:29 PM
  5. Raising Voltage from 12 to 24v
    By Marcvw79 in forum Hobbycnc (Products)
    Last Post: 03-11-2008, 11:29 PM
