585,712 active members*
3,991 visitors online*
Results 1 to 15 of 15
    2139
    adding a longer bed
    Anyone ever added the conversion bed to a minilathe, instead of replacing the bed. For example making the 7x10 to a 7x22... by using the 12" bed extention kit bolted somehow to the end of the lathe.
    http://www.littlemachineshop.com/pro...ProductID=1525
    I am thinking of trying this. If it's impossible, I would like to know before hand...
    Eric
    I wish it wouldn't crash.
    Jun 2003
    3312
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    6855
    Good question, I two would like to stretch my lathe.
    2139
    Thanks! Just what I was looking for.
    Eric
    Nov 2003
    181
    It's doable but it's going to take some time. You might have to do some milling to the extension to make it fit though. Make sure that you've got spaces you can put shims in and that you have a long sturdy flat surface to mount the lathe and the extension to. After you get everything half tight you'll have to figure out a way of running a dial indicator over the joint to the extension and adjust from there. If the bedways arn't flame hardened you could have some fudge work with block sanding. Having a straight good bed on a lathe is a nice thing to have. One of the Lathes at my work has about .003 taper in 3 inches right near the head stock, belive me you don't want that. Just my two cents.
    Carl
    While it takes some work, it's definately possible to extend the 7" minilathes this way. I know of several other who have also extended their lathes this way with good results. The concept is pretty straighforward & as always the devil is in the details. I think the most common stumbling block is the variation between beds where the gibs ride. There are a couple ways around that, one would be to mill or file a uniform surface on one bed to match the other. I chose to go the adjustable gib route, it's a less perfect solution but it had the advantage of being simple. I simply adjust the gib to allow it to ride best over both halves. It's not like I'm doing fine pitch threading that far from the headstock.
    a few folks have gone with a much shorter extension ( in the 4"-6" range ) and have gotten good results. That had actually been my original idea, to just add a small extension where I could "park" the tailstock and gain some usable real-estate. Once I started playing around with it I decided to add some significant length and the website details what followed. The same idea would still apply though, take one of the LMS extended beds, combine it with the setback tailstock and then add a small extension to park the tailstock on and you'd have something in the ballpark of a 7x17. The bed kit & tailstock alone get you to a 7x15 & extensions only add to that.
    Dave
    www.broncosaurus.net
    2139
    what do you mean "variation between beds"? In what way do the gibs vary?
    Eric
    The gibs themselves don't really vary any more than the rest of the machine does. What I meant was that the gibs ride along the bottom edge of the bed, and while this is a machined surface there doesn't seem to be a whole lot of QC involved when it comes down the the actual thickness of each & every set of ways. The most common problem that crops up when doing this is that the ways of the donor bed are from a different batch of castings and the ways are marginally thicker or thinner than the bed of the original lathe. If you're lucky the two beds will be very close in size and it's not an issue, otherwise there's going to be a step at the joint and the gib will catch on it. If the step isn't too bad you can run the gibs a little loose but that compromises accuracy and only gets you so far anyways. The best solution is to make the two even by either milling down or building up the outside edge of the bottom of the ways where the gibs ride. For some reason most of those I've talked to had donor beds that were thicker so it was a matter of milling or shaping the edge down a bit to match the original lathe. The only one I know of that had to build the area up did so with moglice and seemed happy enough with the results.
    Dave
    Oct 2003
    927
    If one does this extension by obtaining a "replacement" bed, then by taking the smaller of the two(if they differ from casting lots), and using that as the main machine bed, then the extension bed would only need to be taken down instead of being built up to get the two sections to align.
    ..just my $.02 worth..
    2139
    Are we talking the flat (rear) section of the ways, or the front half hex shaped part, or both. I can see machining a few thou of the flat section if need be...
    Eric
    Jul 2003
    200
    Eric,
    There's a yahoo group devoted to this, called 7x25 cnc minilathe, or some such...
    Pictures, examples, discussion.
    Hope this helps,
    Ballendo
    2139
    found it, thanks.
    Eric
    Oct 2003
    927
    I'm interested in this too...
    Where did you find it? what is the correct name?
    I did several searches but yielded nothing...
    Oct 2003
    927
    found it
    May 2017
    25
    Re: adding a longer bed
    I know this is long since dead.... but I did exactly as BroncoBill said. I milled the end of the casting and bolted up a weldment. I'm also using linear rails, so the whole level thing becomes moot... works great! https://www.cnczone.com/forums/mini-...ml#post2449582
  1. The plan is no longer available?
    By mamexp in forum Momus Design CNC plans
    Last Post: 03-23-2012, 06:11 PM
  2. Longer parallel cable or longer steper wires?
    By jvanick in forum Hobbycnc (Products)
    Last Post: 09-13-2008, 11:51 AM
  3. Replies: 0
    Last Post: 05-28-2008, 04:37 PM
  4. New longer Y
    By cncadmin in forum Benchtop Machines
    Last Post: 08-12-2004, 12:40 PM
