585,763 active members*
4,055 visitors online*
    Jun 2019
    Uneven cutting across the laser bed
    Our new 100w laser cuts very well at the left end of the work, but does not cut through on the right. We raised the bed on the right end and it helps but not enough. The material is 3/16 inch basswood - it cuts through on the left and about half way on the right. Mirror problem of bed problem?
    Nov 2008
    644
    Re: Uneven cutting across the laser bed
    It’s hard to say for sure but 100w should have no issues with 5mm solid wood. I’d align the machine and level the bed. Make sure the beam isn’t hitting the inside of a nose cone.
    Jan 2008
    940
    On my unit my gantry was loose on the right hand side and I needed to adjust it so it was even all the way across
    Aug 2018
    28
    If you leveled the worktable correctly, it should be a problem of aligning the mirrors.
    If your machine does not cut in the whole right part (front and back) you should check the alignment between mirrors 2 and 3 (the one on the bridge and the one in the head), using the regulators of the second mirror and verifying that the lightning is striking in the middle of the third mirror on the right and on the left of the work table. Then you should use the regulators of the third mirror to regulate that the beam comes out correctly through the middle of the head.
    I also recommend checking the lens cleaning.
    Good luck!
    I am an experienced laser technician.
    User of laser cutting machine Buchicnc EVO 14.
    User of laser recorder EVO 5.
    CNC router user, with 3 x 2 m table Auto Tool Changer
    I usually design my own laser files designs for laser cutter & laser engraver with CorelDraw, Laser Cut 5.3, RDWorks V8.
    Laser cutters & CNC Routers BuchiCNC USA
    CNC Router ATC
    EVO 14
    Soy tecnico de laser con experiencia.<br />Usuario de maquina de corte laser Buchicnc EVO 14.<br />Usuario de grabadora laser por fibra EVO 5.<br />Usuario de router CNC, con mesa de 3 x 2 mts Auto Tool Changer<br />Diseño mis propios archivos maquinas de corte laser con CorelDraw, LaserCut 5.3, RDWorks V8.<br /><a href="https://buchicnc.com" target="_blank">Estas son mis maquinas de corte láser BuchiCNC</a><br /><a href="https://buchicnc.com/producto/maquina-de-corte-laser-evo-14/" target="_blank">EVO 14</a><br /><a href="https://buchicnc.com/producto/maquina-de-corte-laser-evo-5/" target="_blank">EVO 5</a><br /><br /><a href="https://buchicnc.com/en/" target="_blank">Laser cutters &amp; CNC Routers BuchiCNC USA</a><br /><a href="https://buchicnc.com/en/product/cnc-router-mr-atc-6-standard-line/" target="_blank">CNC Router ATC</a><br /><a href="https://buchicnc.com/en/product/laser-cutting-machine-evo-14/" target="_blank">EVO 14</a>
    Dec 2022
    Quote Originally Posted by gnylander View Post
    Have the same problem, the mirrors is aligment, and the bed area, but still the problem, ¿do you find a solution?
