585,762 active members*
4,088 visitors online*
    Oct 2017
    9
    Laser perpendicular to surface? Distance?
    Hello everyone,
    i want to build a machine to cut 3d items. I am choosing between laser and milling. Do you know is the laser beam needs to be perpendicular to the surface of the item at all times and what is the maximum distance from the head to the item surface? Also do u suggest CO2 or fiber lasers for cutting 1/4'' plastic (nylon 12).
    John
    Aug 2018
    28
    Re: Laser perpendicular to surface? Distance?
    Hello,
    Normally the laser beam must be perpendicular to the material and must respect a distance to the material called focal distance determined by the focusing lens.
    There are laser cutting machines that work like a robotic arm, but that's already beyond my knowledge.
    Best regards
    I am an experienced laser technician.
    User of laser cutting machine Buchicnc EVO 14.
    User of laser recorder EVO 5.
    CNC router user, with 3 x 2 m table Auto Tool Changer
    I usually design my own laser files designs for laser cutter & laser engraver with CorelDraw, Laser Cut 5.3, RDWorks V8.
    Laser cutters & CNC Routers BuchiCNC USA
    CNC Router ATC
    EVO 14
    Soy tecnico de laser con experiencia.<br />Usuario de maquina de corte laser Buchicnc EVO 14.<br />Usuario de grabadora laser por fibra EVO 5.<br />Usuario de router CNC, con mesa de 3 x 2 mts Auto Tool Changer<br />Diseño mis propios archivos maquinas de corte laser con CorelDraw, LaserCut 5.3, RDWorks V8.<br /><a href="https://buchicnc.com" target="_blank">Estas son mis maquinas de corte láser BuchiCNC</a><br /><a href="https://buchicnc.com/producto/maquina-de-corte-laser-evo-14/" target="_blank">EVO 14</a><br /><a href="https://buchicnc.com/producto/maquina-de-corte-laser-evo-5/" target="_blank">EVO 5</a><br /><br /><a href="https://buchicnc.com/en/" target="_blank">Laser cutters &amp; CNC Routers BuchiCNC USA</a><br /><a href="https://buchicnc.com/en/product/cnc-router-mr-atc-6-standard-line/" target="_blank">CNC Router ATC</a><br /><a href="https://buchicnc.com/en/product/laser-cutting-machine-evo-14/" target="_blank">EVO 14</a>
  1. Laser power measurement vs. distance
    By Bertho in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-18-2018, 10:31 PM
  2. Focus distance of Chinese laser lens and other quirks
    By nalmeida in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-28-2015, 10:42 AM
  3. 50 w Laser with z axis table what distance
    By justy22 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-04-2013, 02:43 PM
  4. Get Perpendicular
    By Herbertkabi in forum Uncategorised MetalWorking Machines
    Last Post: 07-12-2008, 02:41 PM
