586,005 active members*
5,034 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Turret fadal only cw
    Mar 2019
    Exclamation Turret fadal only cw
    HI, HAVE A FADAL 4020 HT 1994, I CHECK ALL THE RELAYS AND THE PUSH RECIRK IT FUSES AND THE PROBLEM IS HERE.
    I CHECK THE CONTINIUS IN THE ALL WIRES AND ALL IS CORRECT MY TURRET IS A GEAR MOTOR BODINE 115v 1:30 THE MOTOR IS IN GOOD CONDITION
    I DO NOT KNOW WHAT MORE PROVE IN THIS PROBLEM, ANOTHER IDEA??
    THANKS
    Mar 2014
    22
    Re: Turret fadal only cw
    sounds like you have a broken wire in the harness.....
    Jan 2015
    417
    It is either you fuse or the solid state relay on K5 check those first or swap em temporarily. If thats not it it is the Capacitor on the end of the board there to the right ..... So if you swap the capacitors and your slide stops working you'll know its the capacitor buy a new capacitor from McMaster-carr
