585,880 active members*
6,497 visitors online*
    Jun 2019
    Exclamation OSAI 10 series configuration
    Hello everyone,
    First of all I'm pretty new with CNC's.
    I have CNC machine with Osai 10 controller and I had error 'HD001 file configuration not found', then I entered the menu using the F1 key. Numeric control configuration was empty. I do not have any backup data.
    I wonder if anyone can briefly explain how to set up and compile the configuration?
    Thanks in advance!
    Jul 2014
    39
    Re: OSAI 10 series configuration
    Quote Originally Posted by stipe991 View Post
    Hello everyone,
    Thanks in advance!
    I have the same problem.
    Do you find how to fix that?
    Jun 2021
    4
    Need to backup the settings for the osai.
    I had the same problem. It's a file that contains all the equipment ( drivers, servomotors etc from your setup).
    You need to restore data for the Osai, >> BootControl >> Security >> Restore.
    If you don't have the file, then is more complicated and should contact the manufacture firm.
    Hey I got a question, mine isn't showing the part programming menu, anychance anyone knows how to bring it back. Kinda new into the Router business got my first machine was running fine got the program from the usb to the controller until it disapeared anychance anyone here knows how to bring it back
  1. OSAI OPEN Series
    By vincent.pomerleau in forum Commercial CNC Wood Routers
    Last Post: 08-14-2017, 07:44 PM
  2. Newbie - communicating with old OSAI Series 10 controller units
    By GeometryShop in forum Controller & Computer Solutions
    Last Post: 01-18-2017, 10:33 PM
  3. OSAI Series 10 Controllr - Create New M Codes?
    By AlexDoran in forum G-Code Programing
    Last Post: 01-17-2017, 06:44 PM
  4. Series 1 Boss 3 - Configuration
    By 1875 in forum Bridgeport / Hardinge Mills
    Last Post: 02-04-2016, 08:16 PM
  5. Vexta PH series 8 wire configuration
    By rboeser in forum Stepper Motors / Drives
    Last Post: 07-13-2005, 05:15 PM
