585,722 active members*
4,361 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Timing pulley slipping on gearbox shaft
Results 1 to 11 of 11
    Sep 2018
    5
    Im not certain this is the correct forum category for this question... if not, please recommend correct forum topic.
    I have a custom built CBC Hotwire machine with 2 animatics motors (x&y), Apex dynamics gear boxes connected to steel timing belt pulleys. The x pulley is slipping a little. Enough to make circles with opposing flat sides. The x gearbox shaft key is worn & The 2 set screws have worn into the shaft a little. I can still run machine but it’s off a little due to x axis timing pulley play on shaft. New gearbox is $1,100 min. Looking to attempt fix before buying new gearbox and pulley because it will probably wear new shaft again. Looking for a suggestion on the strongest locking type pulley on the shaft to avoid future slip & wear on shaft and pulley key slot. I.E. adding flat sides to shaft for set screws, adding more set screws on new pulley, custom fabricating a timing pulley onto taper bushing? Or other ideas. This is probably a common issue I’d imagine.
    Thanks Bill
    Attached Thumbnails Attached Thumbnails C649388D-7FFF-4DDB-9185-8FEF5424BF54.jpg
    May 2015
    686
    Re: Timing pulley slipping on gearbox shaft
    Hhy don't you just remove the setscrews one at a time and drill a hole in the shaft and replace?
    Rod Webster
    www.vehiclemods.net.au
    Put loctite on the shaft and pulley.
    Sep 2018
    5
    Thx or idea. do you recommend the strongest Loctite? Could I still pull of the pulley later on with pulley puller?
    Sep 2018
    5
    not sure if reply went thru. thanks for suggestion. I think that would help. I'll probably broach a new key slot in the pulley bore too. add a couple more set screws. and loctite everything.
    Jul 2018
    6318
    Hi William - I Only use loctite on my pulleys. No screws or keys. I use permanent grade loctite. If you ever need to get them off a little heat from a heat gun and they come off easily. But the plan is for them never to come off. Peter
    The Difference Between Red, Blue, Green and Purple Threadlockers - Henkel Adhesive Technologies Blog
    Quote Originally Posted by WilliamKinsey View Post
    Yes, I'd use red loctite. If you need to remove it later, heat it with a torch, and you'll be able to pull it off.
    Sep 2018
    5
    Thanks for info????
    Sep 2018
    5
    Thank you for the recommendation. And link. Whatever I end up doing loctite will be involved.
    Sep 2005
    1740
    If you have a gap to fill as a worn shaft you might look at the Green Loctite, read the spec's before deciding.
    Aug 2010
    Thanks for input. ‘I’ll check out green loctite
