585,729 active members*
4,527 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Timing pulley slipping on gearbox shaft
Results 1 to 11 of 11
Threaded View
    Sep 2018
    5
    Im not certain this is the correct forum category for this question... if not, please recommend correct forum topic.
    I have a custom built CBC Hotwire machine with 2 animatics motors (x&y), Apex dynamics gear boxes connected to steel timing belt pulleys. The x pulley is slipping a little. Enough to make circles with opposing flat sides. The x gearbox shaft key is worn & The 2 set screws have worn into the shaft a little. I can still run machine but it’s off a little due to x axis timing pulley play on shaft. New gearbox is $1,100 min. Looking to attempt fix before buying new gearbox and pulley because it will probably wear new shaft again. Looking for a suggestion on the strongest locking type pulley on the shaft to avoid future slip & wear on shaft and pulley key slot. I.E. adding flat sides to shaft for set screws, adding more set screws on new pulley, custom fabricating a timing pulley onto taper bushing? Or other ideas. This is probably a common issue I’d imagine.
    Thanks Bill
    Attached Thumbnails Attached Thumbnails C649388D-7FFF-4DDB-9185-8FEF5424BF54.jpg
