585,667 active members*
4,160 visitors online*
Thread: blockages
    Jun 2019
    blockages
    hi all,
    Having recently put in a .030" mixing tube for the job, it keeps on blocking up after about 30 seconds. the material is 1.25mm stainless steel. normally we use a .040" mixing tube which rarely has blockages apart from the standard, but with this .30" mixing tube we cannot even cut one part out.
    any ideas?
    thanks
    Jun 2019
    Quote Originally Posted by dickens28 View Post
    hi all,
    any ideas?
    thanks
    Try running a less course garnet or slow down your abrasive feed rate.
