585,967 active members*
4,441 visitors online*
    Oct 2018
    Question Problems with Planet CNC TNG
    In our daily use of Planet CNC TNG, we have encountered the following problems:
    1: The emergency stop can be released in the software even though it is still pressed. No settings are available.
    2: No message appears if the G-Code exceeds the limits when loading the G-code. no settings are available.
    3: The startup script _Start.gcode is not executed, even though it is in the folder "Profiles \ Default \ Scripts".
    Unfortunately, the topic of scripting is very poorly documented. There is no overview of the entire scripts and their special functions.
    I am very frustrated right now. Does anyone have any idea how to solve my problems?
    Thanks in advance
    May 2019
    28
    Re: Problems with Planet CNC TNG
    If you have any specific questions regarding scripting I would be glad to lend a hand.
    Please note that for TNG the scripting is basically G-Codes, M-Codes, O-Words, Operators, Functions and addressable hardware variables ... so there is no scripting language you need to learn ... it's more like scripting syntax which is easily denoted on the existing scripts inside TNG.
    PlanetCNC's TNG G-Code PDF explains the individual codes and under "Usage" it shows you how to reference them in a script or for MDI input. Further tutorials on how to use o-words, loops, conditional statements, etc. are available on their website and a must because they are critical to scripting.
    As for the variables, I found them by looking at State5.txt and used common sense to discern their meaning ... like #<_current_tool> under Modal State. As a preamble, I would do the tutorial for creating custom tabs first (State3.txt) which are very cool & useful.
    Chances are that if you look at the existing scripts that are included with TNG ... you will become quite proficient in no time. If you need help with the syntax for reading inputs or outputs I can help with that too.
    There is a new version of TNG coming out soon and hopefully that will resolve some of your frustrations.
    Apr 2012
    91
    Ski Patrol - Don`t suppose you could be persuaded to write a Scripting Tutorial??
    May 2019
    28
    @ Eatonbrayer Sure ... I have reached out to PlanetCNC for guidance as to how best to approach the subject.
    Apr 2012
    91
    Many thanks for your action on this. I think it will be of great value to myself and the community here, not to mention Planet CNC.
  1. Problems with Routakit SDX and Planet CNC electronics
    By coachjohnson in forum Uncategorised WoodWorking Machines
    Last Post: 10-04-2018, 03:10 PM
  2. Planet CNC
    By yar20 in forum PlanetCNC
    Last Post: 04-26-2018, 05:31 PM
  3. USB CNC Planet-cnc
    By Pysiek in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-01-2011, 12:20 PM
  4. Cremation Bad For The Planet
    By Geof in forum Environmental / Alternate Energy
    Last Post: 04-25-2007, 09:15 AM
