Hello all,
I'm trying to do machine data collecting from my '15 TM-3P via Serial. It does not have the new "Next Gen" OS, but the version prior to that roll out. It does have ethernet enabled but its not currently connected. I do have macro's enabled as well as setting 143 enabled.
I have tried a myriad of different baud rates, hand shakes, parities and so on. I have tried use hyperterminal, PuTTy, Cimco and an array of other serial hosts. I don't get any type of handshaking with the machine.
I have also tried sending/receiving over DNC without success. Any Q command I throw out, does not return any values.
I have tried connecting to my pc with DB25, DB9 and USB Serial converter. I have jumped the serial connector pins and can confirm RX/TX work via a loop back test.
I do have a next generation machine as well and on there I have an option how to post data collection, ie Serial or TC/IP. I have that machine working perfectly. Is there some setting I'm missing where I tell the machine to post over serial versus TC/IP? I don't see an option to disable ethernet, but I could be missing it. It is currently not connected to a ethernet cable.
I'm at a lost on what to try next.
thanks!
