585,741 active members*
5,149 visitors online*
IndustryArena Forum > CAM Software > Mastercam > rotary advanced PLEASE HELP
    Nov 2007
    361
    Hello to all , I am tring to machine this part using a 4th axis . I have been able to come up with a basic tool path using the axis sub. but I need to do a little bit more ot the part that axis sub is not made for or I cant get it to do what I am wanting it to do .. anyway I have attached a mastercam 2018 part file that i am trying to machine I need to cut the material ni between the ribs without cutting into the wall on the right end of the part . I have to use a 1/4" carbide endmill because the drawing calls for a 1/8" corner radius in the corners on the right newd of the part . I have played around with rotary advanced but I dont know what it is asking for in each box . If someone could expaln what the steps are and what each box is asking for would really help :drowning:
    Aug 2015
    108
    Re: rotary advanced PLEASE HELP
    Try this.
    The rotary diameter is the diameter of your part.
    Attached Files Attached Files
  1. Replies: 3
    Last Post: 09-21-2015, 01:36 PM
  2. One of the most advanced
    By jjacoby in forum Uncategorised CAM Discussion
    Last Post: 06-10-2012, 02:52 AM
  3. Adding a rotary encoder to a large Rotary Table
    By small.planes in forum Mechanical Calculations/Engineering Design
    Last Post: 04-27-2012, 07:27 PM
  4. Tipping rotary haas rotary axis
    By mfpuller in forum Mastercam
    Last Post: 04-04-2011, 04:16 PM
