585,977 active members*
3,966 visitors online*
IndustryArena Forum > Maintenance in General > Maintenance DIY Discussion > 3 phase motor from Cincinatti #2 Tool and cutter grinder not working
    Hello Everyone,
    I purchased a Cincinatti #2 Tool and Cutter Grinder on Ebay and have just hooked
    it up...nothing.
    I checked first to determine that it was wired for Low Voltage 220 3 phase
    I am getting power to the motor as 206 volts to each leg. I live in Mexico so thats all we get here.
    I disconnected all 9 motor leads and checked the conductivity of each possible combination
    of leads 45 in total.
    8 of these combinations are closed and I believe that only 6 should be closed.
    Can anyone verify this or give me another test to determine if this Spindly Motor will
    need to be rewound?
    Best Regards,
    Preston
    Re: 3 phase motor from Cincinatti #2 Tool and cutter grinder not working
    Ok, found the problem...
    2-8 is open vs 1-4 and 3-6 have 7.1 ohms resistance.
    Best Regards,
    Preston
  1. 3rd gen tool and cutter grinder
    By KWTool in forum Toolgrinding / Toolgrinding Machines
    Last Post: 02-03-2019, 02:11 PM
  2. CNC tool and cutter grinder
    By charles-IPC in forum Uncategorised MetalWorking Machines
    Last Post: 03-07-2018, 10:57 AM
  3. Tool & Cutter Grinder and Wire Cutter Plans
    By newport in forum CNC Wire Foam Cutter Machines
    Last Post: 04-17-2009, 10:15 PM
  4. tool and cutter grinder prgramming!!!
    By brainlessme in forum G-Code Programing
    Last Post: 04-27-2007, 03:57 PM
  5. Walter CNC Tool and Cutter Grinder
    By valexim in forum Employment Opportunity
    Last Post: 01-21-2007, 02:31 AM
