585,962 active members*
3,420 visitors online*
IndustryArena Forum > CAM Software > Mastercam > unrolling a circle
    Mar 2008
    375
    Question unrolling a circle
    hello everyone
    I am trying to see if mastercam can do this?
    so I have a 10 inch O.D with a wall thickness of .250 so I.D is 9.5 inches
    I am trying to see if I can unroll it (lay it flat) just trying to see how long of pcs of sheetmetal I have to cut?
    hope that made some kind of sence? basically just trying to unroll a circle flat .
    thank you
    Re: unrolling a circle
    2 x pi x radius
    1224
    You might need to visit a sheet metal forum for advice on where the neutral axis of a rolled cylinder is likely to be if the accuracy is really important. Its also going to take some fairly serious rollers to persuade 1/4 inch steel to assume the curve.
    Dec 2008
    3109
    It's a bit more awkward than that
    .... if rolling or bumping a sheet, the OD stretches & ID compresses...
    roughly speaking, the mean sheet thickness is calculated for the bend
    ... so ... 9.75 x pi = 30.63" would be the cut length
  1. A circle, a simple circle. How hard can it be?
    By camasaki in forum Hobby Discussion
    Last Post: 07-18-2019, 09:21 AM
  2. Draw line tangent from small circle to large circle
    By WEDDLETON in forum ViaCad / Shark
    Last Post: 07-30-2014, 05:53 AM
  3. Replies: 16
    Last Post: 02-05-2014, 08:21 PM
  4. write gcode for circle with 4 small circle inside it
    By Farzaneh_2010 in forum G-Code Programing
    Last Post: 12-13-2010, 05:24 PM
  5. unrolling a parasolid
    By camtd in forum Mastercam
    Last Post: 02-16-2008, 04:43 PM
